Retrovisores abatibles y climatizador
11 respuestas en este tema
#1 Jerogliphic
Jerogliphic
    ¡¡FRIGORIPHIC!!
  • 2.852 mensajes
  • Interests:Coches, Música, Viajes, Arquitectura...
  • Coche:(BB1) H22A2
Escrito 23 agosto 2005 - 00:36:21
Primero la explicación de como currarse los retrovisores abatibles, lo que no se es donde conseguir los JDM, imagino que en Ebay o similares.
JDM folding mirrors wiring / install guide into 4gen prelude « » 2:59 AM 12/19/2003 Reply Edit
Finally I have found solution to install this nice estoy. Also, a lot of thanks to elnoyl for his help.
I decided to write this guide as nowhere in the net I haven't found a guide for prelude...
So, let's go to the game:
Nomenclature I used:
LHD - left hand driven car
RHD - right hand driven car
oem - our components
JDM - japan components
1. Mechanical
The very important thing is to say that JDM mirrors are from RHD cars. The mirrors are in fact the same, but the supporting elements not. They look almost as LHD ones, but the angles of neutral mirror position are different. Also, I have never thought before that even in ours LHD cars the left and right mirror supports are different. It can be good seen if you see your car from a higth building. The rigth mirror has bigger angle that the left mirror. It is because driver is sitting on left side of car. In Japan it is reverse.
If you will put directly RHD mirrors into a LHD car (in neutral position, into middle of regulation range) you will see only a side of your car into right mirror and some landscape into left one... If you will try to adjust the mirrors you will get a little better view, but you will achieve the extreme points of regulation range. It is neither nice, neither safe. Some people try to improve the viewing range by glueing a small round wide angle mirror on the corner of mirror glass. It is not nice too...
My idea was finally to leave all exterior parts from my oem mirrors as they are - in such case you will not need to repaint the jdm mirrors - almost always you will get them into different color - and to swap only the "skeletons" - the only thing that mechanically differs oem and JDM ones...
To do this first you have to demount oem mirrors from the car. Then you disasemble completely all mirrors you have: 2 JDM and 2 oem:
- disassemble conectors - a needle or an office binder is a very useful tool (note the position and colors of wires in the connector), take off black gummy weatherstrip, take off a small screw holding the wire harness into the support,
- take out 4 screws fixing mirrors to their supports: 3 are located under the mirror, the 4th one is located from support side,
- disassemble mirror from support, carefully pulling the wire harness,
- take off a mirror glass and a small black unpainted side cover. The side cover is held by two small hatches. the hatches are visible if a glass is taken off. Use a long small long screwdriver to push them when pulling the cover,
- when the black cover is extracted you will see 2 small screws - take them off
- take off 3 bigger screws holding the mechanism into mirror plastic cover (visible when mirror glass is taken off).
The mechanism is extracted. Just swap the jdm mechanisms into your oem mirrors.
Fix frankenstein mirrors on oem supports. In my case assembled oem mirrors with JDM mechanisms have not wanted to get directly the original oem supports. There are 2 blocking things:
1. Our friends from japan have made a small dirrerence in shape (almost invisible by eye, but well blocking), especially in proximity of 4th screw (the one from the support side). Take off some metal from the part that enters to the support - I used a grinder to take off maybe 0.5 - 1.0 mm of metal. But you will see yourself if it enters or if it is necessary to fileing some material more).
2. There is also a small positioning point on the oem support (does not exist on jdm support), the JDM mechanism has the same one in the same place (but oem mechanism has not) - you cannot have both - just cut one of them - I have cut a one from oem support (compare two supports and mechanisms to see where the points are).
Fix the wire holder and weatherstrip. Install jdm connectors. Mount assembled mirrors on the car.
Now you have jdm mirrors LHD version.
2. Electrical
First, I want to say, that I haven't found any possibility that JDM mirrors could operate automaticaly when you use your e-brake, switch off ignition, open door, etc. as it may be suggested in many places in the net. Looking the components and redesigning the wiring diagram (I didn't get any documentation with the mirrors) I am almost 100% sure that in JDM solution they operate ONLY if user press the fold button.
You should get with mirrors two toys: a JDM switch with fold button and a relay.
- button: the only difference is an additional blue/yellow wire. Extract this wire from jdm connector and put it into your oem one. By pressing the buttom +12V is given to the blue/yellow wire. In other words the relay is activated by a positive pulse (this blue/yellow wire goes directly to relay).
- relay: a big challenge, especially as it doesn't exists outside of jdm and is hard (=expensive) to get... my greatest fear was not to blow out the relay by an incorrect wiring...
The relay for prelude is different of civic or integra relay. It has 7 wires instead of 5. The colors and connections are (thanks again to elnoyl):
blue/white - right mirror fold motor,
red - right mirror fold motor,
blue/yellow - from the switch,
black - ground,
white/yellow - power (+12V constant)
blue - left mirror fold motor,
blue/red - left mirror fold motor.
The white/yellow wire should be constant +12V powered to assure the correct fold operation when ignition is cut (ex. you push the fold button and immediately take off the key from ignition). If it would be not constant but accessory/ignition on powered you would risk to take off the key faster that the mirrors would fold completely.
The relay is current-sensitive, there are no end switches in mirrors. The power to the mirror is cut off when the relay detects a highter current.
In the same way, if you want to have mirrors operated by your car alarm, you should provide a +12V pulse when arming/disarming the alarm to the blue/yellow wire - many alarms has this option.
That's all...
pues eso......
#2 Jerogliphic
Jerogliphic
    ¡¡FRIGORIPHIC!!
  • 2.852 mensajes
  • Coche:(BB1) H22A2
Escrito 23 agosto 2005 - 00:38:18
y ahora lo del climatizador, es un link a Honda-tech.com, la página esta de p#%@ madre, os la recomiendo, hay de todo.
Como instalar el climatizador en un cuarta
ala, a currarselo.
Jorge
#3 antrax
  • 38.042 mensajes
Escrito 23 agosto 2005 - 01:00:22
si, en ebay los he visto a veces ;)
#4 Preludio
Preludio
    In love with H22
  • 1.325 mensajes
  • Interests:Racing cars
  • Coche:Accord Coupe VI
Escrito 23 agosto 2005 - 06:47:30
Periodismo de investigación ..... del que me gustaaaaaa :P
#5 Redbullet
Redbullet
    Elpontos
  • 5.454 mensajes
  • Interests:Alquilar Circuito
  • Coche:Prelude / Civic / Prelude - R
Escrito 23 agosto 2005 - 12:32:27
Muuuchas gracias!!
#6 fernan
fernan
  • 356 mensajes
  • Coche:calamar seat
Escrito 11 diciembre 2005 - 21:30:08
en el ebay en uk hay 2, eso si, solo esta la parte que se ve.
por lo que pone jero,parece bastante dificil, solo seria que alguien que estubiera bastante mas estudiado el coche por dentro que hiciera la prueba.
aunke otra cosa mas facil, sera pillar el manual del nuestro y el manual del que lleva el clima y ver las diferencias, asi seria bastante facil de hacerlo creo.
#7 turbolude
turbolude
  • 437 mensajes
  • Coche:Prelude 2.2 5ª & Nissan 200 S13
Escrito 12 diciembre 2005 - 13:20:51
Yo ya tengo los espejos retractiles a falta de montarlos y la semana pasada compre esto en ebay (BB6 climate control unit):
http://cgi.ebay.com/.....AMEWN:IT&rd=1
Me he informado y es más facil montarlo en el 5ª en el 4ª.
Salu2
#8 Kosei
Kosei
    V-TEC Fan!
  • 4.729 mensajes
Escrito 12 diciembre 2005 - 13:46:28
Vaya Alex, muy interesante tío, lo que pasa que 300$ es una pasta. Seguro que tu lo has pillado más barato.
Pues ya sabes que espero impaciente el How-To del Climatizador en tu Lude.
Saludos!!
#9 turbolude
turbolude
  • 437 mensajes
Escrito 12 diciembre 2005 - 15:13:59
Saludos!!
No hijo, no. Esa es la puja que gané, más quisiera yo que fuera más barato. Al final con portes se queda en unos 280 € de nada :evil: :pero bueno, mejor no pensarlo. Ya he visto varios y se quedan todos por ese precio más o menos. Asi que, al final me he lanzado.
Voy a montar esto y los espejos, al final voy a tener un Prelude JDM :lol: . No te preocupes, que podré foticos.
Salu2
#10 Kosei
Kosei
    V-TEC Fan!
  • 4.729 mensajes
Escrito 12 diciembre 2005 - 15:33:27
Bueno, la verdad es que merece la pena, son accesorios muy exclusivos y hay que pagarlos. :oops:
Esperamos las fotitos!! Saludetes!! ;)
#11 MiguelCRX
MiguelCRX
  • 849 mensajes
  • Coche:Prelude 4Gen
Escrito 12 diciembre 2005 - 16:21:40
yo como vi que era una movida poner el clima en el prelude lo vendi y me compre el 300 que ya lo lleva integrado jajaja, ahora solo me faltan los retrovisores retractiles :P si existen que a saber :D
#12 preludei20
preludei20
    preludei20
  • 1.048 mensajes
  • Interests:Motores,mi moto y mi coche.
Escrito 15 diciembre 2005 - 20:49:34
Jero tio k movida palos retros ¿no?
Lo hiciste como viene explicado??????
y lo del clima despues de ver el montaje me he hechado atras, me parecio muy rebuscado¿alguien de por aki lo ha montado?
