máxima medida en llantas para 5ª, en altura y anchura?
Escrito 04 septiembre 2004 - 18:25:07
Haber si alguien sabe algo del tema. Gracias
Escrito 06 septiembre 2004 - 08:36:50
Escrito 06 septiembre 2004 - 13:23:32
Son unas multirradio muy guapas, xo no se decirte marca ni modelo. Le costaron una pasta eso si lo se
Mira a ver si te valen si te hace. y x cierto a ver si te conzco en persona!!! cuando sea la prox Hyundai o a ver si antes en alguna qdada!
salu2 :wink:
Escrito 07 septiembre 2004 - 09:04:46
Escrito 07 septiembre 2004 - 16:01:31
5th Generation Offset Guide
Tamaños de Llanta (Diametro):
Llantas de 16”
205/50 – OEM and recommended 16” size
215/45 - larger contact patch
215/50 - larger contact patch, diameter is slightly larger
225/45 – 20mm larger contact patch, smaller diameter (some tire brands are slightly larger than 225. these may require 7” rims)
Llantas de 17”
215/40 - larger contact patch, recommended tire size
215/45 - larger contact patch, diameter is slightly larger
225/40 – 20mm larger contact patch
Llantas de 18”
215/35 - larger contact patch, consider for show use only (very little protection for your rims)
215/40 - larger contact patch, diameter is slightly larger
225/35 – 20mm larger contact patch, recommended tire size
Llantas de Serie
5th Gen = 6.5" wide rim 55mm
The 5th Gen comes stock w/ 205/50/16 tires
Note: The Type-S rims have a slightly angled spoke, although the same offset, the Type-S rims have slightly less clearance for a larger caliper.
Offset ó E.T.
Llantas de 6.5" de ancho
Less than +38mm - Chance of rubbing the outside lip of the wheel well with this offset.
+38mm to +55mm - Recommended offset for 6.5" rims.
Larger than +55mm - Chance of rubbing the inside lining of the wheel well with this offset.
Llantas de 7" de ancho
Less than +38mm - Not suggested
+38mm to +41mm – Not suggested if you plan on lowering. Chance of rubbing the outside lip of the wheel well with this offset.
+42mm to +44mm – This may or may not work, depends on if you are lowered. Chance of rubbing the outside lip of the wheel well with this offset.
+45mm to +50mm - Recommended offset for 7" rims.
Larger than +51mm - Not suggested. Chance of rubbing the inside lining of the wheel well with this offset.
Llantas de 7.5" de ancho
Less than +40mm - Not suggested
+40mm to +43mm - This may or may not work, depends on if you are lowered. Chance of rubbing the outside lip of the wheel well with this offset.
+44mm to +47mm - This may or may not work, depends on if you are lowered. Chance of rubbing the outside lip of the wheel well with this offset.
+48mm to +52mm - Recommended Offsets for 7.5" rims.
Larger than +53mm - Not suggested. Chance of rubbing the inside lining of the wheel well with this offset.
Tornilleria
Esparragos - 5x114.3
Por todo lo anterior como bien dices unas llantas de 18x8" te van a pegar fijo JMPRO2000 a no ser que cojas un Offset pequeño y trabajes sobre los pasos de rueda ensanchandolos o lo que sea.
La medida máxima recomendada según ese foro es de 18x7,5" y una medida de neumático de 225/35R18 ¡¡¡¡¡MENUDAS PEDAZO DE RUEDAS!!!!
Que conste que luego tendrás que moverlas y lo notaras mucho en prestaciones.
Saludos y espero que os sirva de ayuda :wink:
Escrito 08 septiembre 2004 - 01:40:23
salu2
Escrito 08 septiembre 2004 - 12:12:24
Escrito 08 septiembre 2004 - 13:15:21
Hechar un vistazo porque supongo que alguien también se lo habrá currado para la 4ª gen. pero de todas formas seguro que la mayoria de los datos son válidos para los vuestros.
Por cierto venden un Prelude Rojo al lado de la Estacion de Coslada
de la 4ª generación con llantas de 17" de 6 palos, está cuidado, matricula de Madrid.
Pero solo pone el teléfono. Si a alguien le interesa me apunto el movil.
Sabeis como distinguir si es el 2.2 o el 2.3 ??? Si pone VTEC es el 2.2 no??
Saludos!!
Escrito 08 septiembre 2004 - 14:27:47
si no fijate dentro si todo el cuadro esta negro o tiene se ve el velocimetro, luego tbn el vtec lleva el freno de mano mas a mano
salu2
Escrito 16 septiembre 2004 - 01:06:44
Escrito 01 octubre 2004 - 00:07:21
Vaya peazo de post, lo tengo enmarcado en mi habitación...
Lo más seguro es que monte unas 18x7 , ya que en 7,5 hay muy poco, pero tengo miedo de que al llevar 35 de goma el coche se quede como un bote, ya que llevo la suspensión recalibrada para que vaya durito con las de origen.
También he pensado montarle unas 225/40-17 que pienso que será lo mejor.Sobre todo para el agarre lateral.
Aunque tengo que esperar a recuperarme económicamente, ya que me he pillado un kart de 125cc con 6 marchas, y estoy un poco apurado.
Escrito 02 octubre 2004 - 18:20:29
Q C@$&# un kart de 125 q juguete!
salu2
Escrito 29 junio 2010 - 01:21:25
