S2000 Do-it-yourself (DIY) Mods & Repairs
1 respuesta en este tema
  • 12,630 mensajes
Muy buenas,
Pongo ésto por aquí:
http://www.s2katlant...ods-amp-repairs
S2000 Do-it-yourself Links:
Engine/Transmission:
Changing the oil
Changing the transmission fluid
Changing the differential fluid
Changing the spark plugs
Flushing and bleeding the clutch fluid
Manually changing the clutch fluid
Installing an oil catch can
Reset maintenance and check engine lights
Reset ECU
Reset SRS light
Reset Maintenance Required light
How to do a valve adjustment
Installing a supercharger & aftercooler
Installing a Vortech supercharger
Tightening a Vortech supercharger belt
Replacing a Vortech supercharger belt
Flushing the coolant
Installing a VAFC
VAFC Settings
Installing an aftermarket clutch
Installing an AEM V.2
Map whack
Anti-spin oil filter clamp
Installing a CAI snorkel
Installing a AEM type cold air intake
Removing the stock exhaust
Installing a cat back exhaust
Installing a header
Replacing the MY04+ slave cylinder with a pre04 model
Modifying an existing 04/05 slave cylinder instead of replacing with an 03.
How to gravity bleed the clutch
Cleaning/Replacing the timing chain tensioner
DIY Krank Vent install
Suspension/Brakes:
Replace inner CV joint
Painting Calipers
How to change your brakes
How to install Wilwood big brake kit
Installing brake ducts
Installing Laminar Airflow Brake Ducts
Installing anti bumpsteer control arm
Installing stainless braided brake lines
Replacing the tire rod ball joint boot
Installing/removing shocks
Installing aftermarket coilovers
Installing an X-Brace
Manually changing the brake fluid
Body/Exterior Cosmetic:
How to roll fenders
Installing a carbon fiber hood
How to convert to a 2004
Front bumper and headlight conversion from 00-03 to an 04+ style
Replacing a pre02 soft top with a MY02+ softop with glass window
Lubricating the chassis
Windshield tape removal
How to install a hardtop (pre-04)
How to install a hardtop (MY04+)
How to install static tint to a plastic rear window
Replacing window glass
Installing a hardtop winch
Removing and installing new emblems
Creating a vented hood from a stock hood
Replacing a plastic rear window
How to turn stock exhaust tips blue
How to install and adjust a carbon fiber hood
How to replace the convertible top
Electrical/Audio:
Disable A/C in Defrost Mode
Top Down While Moving
Program keyless remote
Installing an aftermarket head unit
Installing door speakers
Garage opener mod
Subwoofer in footwell
Adding daytime running lights
Installing a shift light
Adding an auxillary passenger door unlock
Installing an auxillary power outlet
Creating speaker brackets for the door
Hardwiring a radar detector
Installing neon footwell lights
Enabeling the keyless entry while the car is started
How to get the radio serial number without taking the radio out
Installing Odyssey fog lights
More Modifry Mods
Interior:
Removing the door panel
Changing the A/C Micron Filter (Cabin Air Filter)
Fixing top rattle in MY04
Lowering the seats
Installing an aftermarket steering wheel
Installing Katzkin seats & reparing seat bolster
Maintenance Schedule for Extreme Conditions.
Maintenance Schedule for normal conditions.
  • 12,630 mensajes
Muy buenas,
Y añado:
http://www.s2ki.com/...ions-1999-2009/
AP1 (1999-2003)
Problem: Why is my carpet always moving around? (MY00 only)
Solution: Technical Service Bulletin
Problem: Oil consumption
Solution: Some owners have said that a catch can has solved the issue.
Fact: Several S2000 owners have reported a oil consumption issue with Mobile 1.
Fact: Early AP1's (1999-2003) have a reputation of burning oil while in Vtec.
Problem: Buzzing from the transmission while decelerating. (MY00-02)
Fact: Leaving the car as is won't cause any damages. AKA clutch buzz.
Problem: Rear window is creased, clouded or scratched. (MY00-01)
Solution 1: Cleaning - Technical Service Bulletin
Solution 2: Rear Window Replacement - Technical Service Bulletin
Solution 3: Upgrade to glass window / Topsonline
Problem: Grinding when shifting into 2nd gear.
Problem: While doing a valve adjustment I've noticed cracked retainers.
Solution: Upgrade to AP2 retainers (better).
Note: Over-revs, miss shifts and oil starvation are the main reasons of engine damage.
AP2 (2004-2009)
Problem: Gear lever pops out of 2nd, 4th or 6th gear.
Problem: CEL P1172 and/or P2A00. (MY06+)
Problem: Convertible top is torn at the lock handle and/or the right rear. (MY05+)
Problem: Dash begins to bubble, blister or wrinkle. (MY06+)
Solution: Dash replacement. Problem description
ALL (1999-2009)
Problem: When accelerating, my car pulls on the left or right side.
Solution: The S2000 is very sensitive to tire pressure. Check tire pressure while respecting the OEM tire pressure specs.
Problem: Clicking noise from rear when moving in first gear or reverse. Sounds like two metal marbles.
Solution: Honda use to torque the axle nuts to 180 lbs. The correct torque is now 230 lbs. Torque your axle nuts.
Problem: Vibration during acceleration
Solution: Pitted cv boot are a common S2000 problem. You can Swap them from left to right.
Link: How to swap cv boot
Problem: Ride height is not the same everywhere / Weird handling
Note: You may still have the spring spacers. They were used during shipment and many have been forgotten.
Link: What spring spacers look like
Problem: Intermittent hesitation during hard acceleration. (MY00-05)
Problem: I'm having trouble starting the car after a spin out at the track.
Solution: Several S2000 owners have reported this.
Problem: Grinding when shifting gear.
Solution: When was the last time you changed your transmission fluid? Honda has updated their MTF formula for better shifting.
Problem: Transmission is hard to shift when cold.
Solution: All S2000 owners have reported this. Give it time to warm up.
Problem: CEL P1399, P0301, P0302, P0303, P0304 (Random Misfire)
Solution: Member Negcamber's checklist
Problem: Whistling sound coming from engine bay.
Solution: Have you recently removed your air box cover?
Problem: My top has a tear in it, how can I fix it?
Solution: Member Dlg04's how-to repair
Problem: Engine noise coming from engine bay. It sounds like cards in a spoke.
Solution: How to replace timing chain tensioner (TCT)
Problem: Wind noise / Soft top noise.
Solution 2: Replace strikers with hard top strikers
Problem: After sitting for a long time, my car doesn't start on the first try.
Fact: Several S2000 owners have reported this.
Problem: Where is my fuel cap release button?
Solution: Look on the driver side door jam, pull on the little black button
Problem: Rattle when in neutral / Rattle stops when clutch is pressed.
Note: Several S2000 owners have reported this.
Maintenance
Engine Oil: 10W30 or 5W40 (Dyno or Syntec)
Transmission Oil: Honda MTF
Differential Oil: 75W90 GL-5 (Dyno or Syntec)
Clutch/Brake Fluid: Dot 3/Dot 4
Fluids
How to change engine oil
How to change transmission fluid
How to change differential fluid
Good general S2000 threads
S2000 Probem info (Thanks to dlg04)
Technical FAQ 2.1
Big list of s2k write up
OEM Filter Summary
Service Bulletin List
CEL List
How to install speakers
Editado por Storm, 26 April 2012 - 14:59:40.
