S2000 Service Bulletins (TSB)
1 respuesta en este tema
  • 12,650 mensajes
Muy buenas,
A pesar de que SÉ que posteé un link a una lista de fallos reconocida por Honda, no la encuentro.
Aprovecho para poner ésto otro (Boletines de Servicio de Honda):
http://www.s2ki.com/...-bulletins-tsb/
In this forum you will find copies of Service Bulletins issued by American Honda for your personal reference and use. This are for informational and entertainment use only. You assume all risks associated with actually performing any instructions contained within. When possible we have provided both the original PDF version of the documents and an HTML conversion of the PDFs. The PDF files are considered the "original" documents, the HTML is simply for convenience. The HTML versions may not be complete or properly formatted. Your milage may vary.
This documents are made available to members only. Please do not republish them or pass them to non-members. Doing so would devalue our membership programs and compromise the time and effort we have put in to bring them to you.
Thanks and enjoy.
Service Bulletin Info and FAQ
2006+ O2/AF Sensor TSB with DTC P1172, P2A00 macr88
2005+ Soft top tearing TSB Luder94
Intermittent Hesitation During Hard Acceleration
Noncompliance Recall: S2000 Taillight Side Markers
Seat Belt Slow to Retract
Convertible Top Creaks Over Rough Roads
Convertible Top Cover Snap Is Broken
Center Console Lifts Up in the Back
EVAP Bypass Solenoid Valve Failure
Convertible Top Does Not Open Properly
Rear Vibration During Acceleration
Reverse or 5th Gear Is Difficult to Select
Product Update Campaign: S2000 Spark Plugs
Transmission Pops Out of 4th Gear
Convertible Top Cover Comes Loose
Wind Noise or Rattle at the Convertible Top
Driver
Water Drips on the Passenger
Safety Recall: S2000 Seat Belt Retractors
Deformed Windshield Molding
Sound Cuts Out While Playing a CD
Grinding When Shifting Into 2nd Gear
Buzzing From the Transmission While Decelerating
Loose Accessory Floor Mat Anchor
Service Manual Update: Rear Window Replacement
Rear Window Is Creased, Clouded, or Scratched
Safety Recall: S2000 Convertible Top Cover
Edit:
Muy buenas,
Lo tengo!
http://clubhondaspir...onda-by-owners/
Editado por Storm, 27 April 2012 - 15:36:29.
  • 12,650 mensajes
Muy buenas,
Edit:
Lo tengo!
Añado éste otro que me acabo de encontrar:
http://www.s2ki.com/...844-s2000-tsbs/
Posted 07 November 2006 - 03:30 PM
Here are the TSB's that a few of you asked for:
*NOTE*
There is no need to worry about TSB's. I just posted them because I had seen some interest in them. TSB's are for techs who are working on your car, not the average driver. If there is a problem that has occured often enough that it catches the Manufactures attention they will relase a TSB's that way the troubleshooting takes much less time and the problem is solved quicky. If there is a recall on the car it is also noted here. This information is usless to most people and unless you understand what it is used for and plan on fixing a problem yourself on your car you will have no use for this information. Unless you are a mechanic, you have no use for this thread.
***IF YOU DONT KNOW WHAT THIS INFORMATION IS OR WHAT IT IS USED FOR DONT WORRY ABOUT IT. THIS INFORMATION IS FOR MECHANICS***
MY2000
Number Date Title
88-023 04/19/2006 Electrical - Battery Test Procedure/Equipment
03-014 02/07/2006 Body - Convertible Top Cover Snap is Broken
02-065 10/28/2005 Body - Convertible Top Won't Work Properly
01-023 09/20/2005 Computers/Controls - Module/Control Unit Updating
01-037 07/05/2005 Body - Convertible Top Rattles/Windnoise
SN050600-011 06/01/2005 A/C - Heater Blows Cold Air, A/C Blows Warm Air
SN050508 05/01/2005 Exhaust System - Catalytic Converter Noise
SN050506 05/01/2005 Wind Noise - Simple Way To Replicate
SN050416 04/01/2005 Engine - Falters/No Power/Won't Rev Over 7000 RPM
SN050407 04/01/2005 A/T - Do Not Remove Torque Converter From Mainshaft
SN050418 04/01/2005 Body - Plastic Body Clip Removal Tips
SN050314 03/01/2005 A/T - Fixing Banjo Bolt Leaks
SN050316 03/01/2005 Engine Controls - Clearing DTC's
SN050311 03/01/2005 Windshield Wipers - Blade Care & Replacement
SN050202 02/01/2005 A/T - Avoiding Fluid Contamination
SN050215 02/01/2005 Audio System - Never Play CD's With Adhesive Labels
SN050105 01/01/2005 Suspension - Creak/Grunt From Rear At Low Speeds
SN050109 01/01/2005 Engine - Oil Recommendation GF-4 Standard
04-073 12/02/2004 Engine Controls - Hesitation on Hard Acceleration
SN040915 09/01/2004 Driver's Air Bag - Replace Torx Bolts Properly
SN040903 09/01/2004 Popping From Front Wheel Upper Control Arm Mount
00-064 08/03/2004 Body - Deformed Windshield Moulding
02-052 07/16/2004 Restraints - Occupant Detection Initialization
04-033 06/16/2004 Recall - Tail Light Side Marker Defect
NHTSA04V257000 06/01/2004 Recall 04V257000: Tail Light Replacement
SN040310 03/01/2004 ABS - Grunts When Doing A Self-Check
SN040308 03/01/2004 M/T - Grinding At Upshifts When Cold
98-011 02/20/2004 Keyless Entry - Remote Transmitter Information
04-009 02/17/2004 Computers/Controls - HIM Module Updating
SN040215 02/01/2004 ABS DTC 51 Or 53 - Diagnostic Tip
SN040211 02/01/2004 Speedo/Odometer Read Excessive Speed & Distance
SN040214 02/01/2004 Headlight Adjustments
SN040203 02/01/2004 Clutch Pedal Is Noisy or Feels Notchy
SN040111 01/01/2004 Engine Oil Recommendations
SN031107 11/01/2003 Blower (Heater) Motor Gets Hot and Blows A Fuse
SN031106 11/01/2003 Air Fresheners - Bad News For Paint Or Plastic
SN031007 10/01/2003 M/T - Hard To Shift Into 1st Gear, Grinds Into Reverse
03-062 09/16/2003 Interior - Seat Belts Slow to Retract
SN030915 09/01/2003 Suspension - Drifting & Pulling At Highway Speeds
SN030813 08/01/2003 Interior & Exterior Trim - Tool To Make Removal A Snap
98-018 07/22/2003 Drivetrain - Revised CV Joint Boot Band/Installation
SN030707 07/01/2003 Catalytic Converter - Rotten Egg Smell
00-088 06/03/2003 Brakes - Brake Disc Refinishing Guideline
SN030502 05/01/2003 Clearing DTCs & Setting ECM/PCM With The HDS
01-008 04/29/2003 Body - Driver Window Won't Go All The Way Down
00-049 04/29/2003 Antitheft System - Type 2 System Operation/Programming
SN030407 04/01/2003 DTC's P0133 & P0420 Set After Manual Trans R&R
03-023 04/01/2003 Body - Convertible Top Creaks/Pops/Rattles on Rough Road
03-020 03/29/2003 Engine Controls/Emissions - OBD II DTC's & Monitors
SN030205 02/01/2003 SRS - Indicator ON with No SRS DTC Set
03-001 01/28/2003 Emissions/Engine Controls - MIL ON/DTC P1457 (EVAP)
02-063 10/29/2002 Drivetrain - Vibration From Rear on Acceleration
02-046 07/30/2002 M/T - Difficult Reverse/5th Gear Selection
02-042 07/10/2002 Campaign - Spark Replacement
00-054 11/27/2001 M/T - Buzz/Rattle on Deceleration
00-055 06/12/2001 M/T - Grinds Shifting Into 2nd Gear at High RPMs
01-029 05/01/2001 Engine Controls - DTC Capture and Downloading
01-038 03/27/2001 Convertible Top Cover - Comes Loose
00-054 12/19/2000 Engine/Transmission - Buzzing on Deceleration
00-099 12/19/2000 Wiring Terminal - Repair Instructions
00-089 10/31/2000 Supplemental Restraint System - Inspection
00-083 10/31/2000 Heater Unit - Water Drips Onto Passenger's Carpet
00-078 10/17/2000 Recall - Seat Belt Retractor Sensor Replacement
NHTSA00V316000 10/04/2000 Recall 00V316000: Seat Belt Retractor Defective
00-048 09/26/2000 Convertible Top Rear Window Replacement - Manual Update
00-063 08/01/2000 Special Tool - Chassis EAR™, Diagnostic Tool
96-012 07/05/2000 A/C - System Performance Testing
00-057 07/05/2000 CD Player - Sound Cuts Out at High Volume
99-053 06/27/2000 Immobilizer Key - Key Code Duplicator
00-050 06/13/2000 Accessory Floor Mat - Anchor Moves From Side to Side
99-018 04/11/2000 Required Special Tools And Equipment,
00-037 04/01/2000 Convertible Top Rear Window - Creased, Cloudy, Scratched
00-015 03/14/2000 Audio Unit with CD Player/Changer - Error Codes
98-019 03/14/2000 Audio Unit - Warranty Exhange/Out of Warranty Repair
00-032 03/07/2000 Paint Codes
00-020 02/04/2000 Recall - Convertible Top Cover
NHTSA00V016000 01/24/2000 Recall 00V016000: Convertible Top/Seat Belt Interference
97-015 12/07/1999 Service Publications - Availability & Ordering
98-031 11/09/1999 Aftermarket On Board Diagnostic (OBD) II Tester
99-030 05/04/1999 Recommended Materials
98-051 08/04/1998 Special Tool Loan Program
MY2001
Number Date Title
01-100 05/13/2005 M/T - Pops Out of 4th Gear
SN050206 02/01/2005 Engine Controls - DTC P0172
SN041204 12/01/2004 Fuel Filler Cap Adapter Available For Testing Emissions
01-001 01/16/2001 Paint - 2001 Paint Codes
MY2002
Number Date Title
04-002 02/13/2004 Fuel/Emissions - MIL ON/DTC P01456 (EVAP System)
SN040106 01/01/2004 Nose Mask Installation Tips
SN030802 08/01/2003 DTC P1456 - Evap System Diagnostic Aid
SN030508 05/01/2003 Audio Unit - Electronically Retrieving Serial Numbers
SN030510 05/01/2003 Audio Unit - Models Which Are Electronically Retrieval
03-012 02/18/2003 Interior - Center Console Lifts Up in the Back
02-013 05/07/2002 Paint - 2002 Paint Codes
MY2003
Number Date Title
SN041206 12/01/2004 Dashboard Switch Not Lit,? Replace Bulb, Not Switch
SN030418 04/01/2003 Odometer - Does It Rack Up Miles When Towed
MY2004
Number Date Title
01-077 04/19/2006 Ignition/Locks - Cutting Sidewinder-Type Keys
05-009 01/12/2006 M/T - Pops Out of 1st or 2nd Gear
03-065 09/23/2003 Paint - 2004 Paint Codes
MY2005
Number Date Title
05-001 01/28/2005 Paint - 2005 Paint Codes
MY2006
Number Date Title
NHTSA06V270000 07/25/2006 Recall 06V270000: Incorrect NHTSA Contact Information
MY2007
NONE RELEASED
Nota: Entrada del FAQ que apunta aquí:
http://clubhondaspir...20#entry1912878
Editado por Storm, 24 October 2012 - 08:59:23.
