Pues eso haber si me podeis iluminar un poko que estoy hasta..... decir que e cambiado ya la ecu y pues eso acepto todo tipo de ideas...
fallo 28 4ws...
Prelude200hp
, 17 junio 2010 00:24:26
4 respuestas en este tema
Escrito 17 junio 2010 - 00:24:26
Escrito 17 junio 2010 - 07:09:00
You pull the 4ws error codes the same way you pull the ECU error codes, just watch the 4ws indicator instead of
the CEL. You reset the 4ws control unit the same way as well, pull the 10A radio fuse in the under hood fure box.
After resetting the 4ws control unit turn the steering wheel to right lock, then left lock the first time you start the car.
How to pull CEL error codes: http://preludeonline...ad.php?t=131369
Code---------------System-----------------------------------4ws control unit pin #'s-----------Affected
10------------------Sub steering angle sensor------------22, 26-----------------------------------Front sub steering angle sensor
11------------------Sub steering angle sensor------------29, 17-----------------------------------Rear sub steering angle sensor
12------------------Sub steering angle sensor------------26, 21-----------------------------------Front sub steering angle sensor
13------------------Sub steering angle sensor------------17, 28-----------------------------------Rear sub steering angle sensor
14------------------Sub steering angle sensor------------NA---------------------------------------4ws control unit
15------------------Sub steering angle sensor------------NA---------------------------------------4ws control unit
16------------------Sub steering angle sensor------------22, 26, 21------------------------------Front sub steering angle sensor
17------------------Sub steering angle sensor------------29, 17, 28------------------------------Rear sub steering angle sensor
18------------------Sub steering angle sensor------------NA---------------------------------------4ws control unit
20------------------Main steering angle sensor---------- 8, 15------------------------------------Front sub steering angle sensor,
Front main steering angle sensor
21------------------Main steering angle sensor---------- 6, 13------------------------------------Rear sub steering angle sensor,
Rear main steering angle sensor
Por lo que parece, es del eje trasero. Doy por hecho que el chasis está ok, y que la alineación es correcta, asique lo que se me ocurre es que tengas un sensor en mal estado...
Escrito 17 junio 2010 - 21:16:50
Mmmmm, de alineacion esta como el culo.. e cambiado mortis, discos etc... y a saber como estaria este chasis..lo alineare haber..
Escrito 18 junio 2010 - 07:04:58
Entonces es normal, casi seguro qeu alineando se soluciona
Escrito 18 junio 2010 - 10:49:17
Seguro que es el alineadoo...Alinealo y veras
