Buenas, vuelvo a la carga pero esta vez con una chorradita:
http://www.carid.com...ts-3134034.html
¿alguno de vosotros que tenga puestas bombillas led interiores podría decirme si esas valen (tipo y tamaño)?
Escrito 19 marzo 2013 - 08:50:04
Escrito 19 marzo 2013 - 09:22:14
Each bulb sold separately.
Originally $7.49 - $11.2420% OFF!
$5.99 - $8.99
Qty: 1
Honda S2000 2004-2009, Interior LED Bulbs by Lumen®. Each bulb sold separately. Replacement bulbs for Interior Dome Light, Map Light and Trunk/Cargo Area Light. Increase the brilliance or customize the color of your vehicle's interior lighting on instrument cluster areas, warning lights, turn signal indicators, and overhead lights. Replacement light emitting diode bulbs from Lumen can illuminate your vehicle's interior, hood, and trunk areas. To ensure that there will be no flickering, bulb out warnings, check engine lights, or other vehicle system data loop errors, the lights are CAN bus compatible. Available in multiple colors.
Lumen LED vs Halogen Bulbs Lumen Error Free LED Bulbs, CAN Bus Compatible Lumen LED Bulbs Colors
General Specifications:
Light Output: 9-LEDs Bulbs. 360 Degree
Light Output: 2 and 3-LEDs Bulbs. 180 Degree
Light Intensity (Max): 9-LEDs Bulbs. White - 50 Lumen, Red - 18 Lumen
Light Intensity (Max): 3-LEDs Bulbs. White - 30 Lumen
Light Intensity (Max): 2-LEDs Bulbs. White - 20 Lumen, Red - 6 Lumen, Amber - 2 Lumen
LED Type: 5050 SMD
Polarized: No
Operating Voltage: 10~14.5 VDC
Type: Replacement Bulb
Bulb Specifications Glossary
Vaya, pues, tampoco especifica mucho.
Busca por "S2ki Light Bulbs" en Google:
http://www.s2ki.com/...ight-bulb-size/
De todas formas, el precio de la web es por CADA bombilla, eh?
P.D: S2000Gr hizo algo hace poco:
http://clubhondaspir...res-de-puertas/
Editado por Storm, 19 marzo 2013 - 09:25:42.
Escrito 19 marzo 2013 - 10:14:04
Escrito 23 marzo 2013 - 10:35:13
He encontrado algo de información sobre el tema:
http://www.s2ki.com/...for-led-lights/
[Interior]
[Dome Lights/Interior Lights/Map Lights]
. FACTORY TYPE: DE3022 (Single circuit, but varying power)
. FACTORY WATTAGE: 5W
. RECOMMENDED REPLACEMENT: 3022-xHP4 (SuperBrightLEDs.com)
. RATIONALE: The 4 LED Festoon bulb works well as it has 120degree LEDs, and wide placement. Snaps right into the existing "festoon" socket.
[Trunk Light]
. FACTORY TYPE: 168 (194 fits also)
. RECOMMENDED REPLACEMENT: WLED-xHP13-T (SuperBrightLEDs.com)
. RATIONALE: Same as license plate light. You want 360 degree spread of light to work like the factory bulb.
Y la bombilla en si:
http://www.superbrig...23-911--375397/
Me queda la duda sobre el relé. Intuyo que será necesario, pero no lo sé seguro. Ni sé qué relé ni dónde está.
Pero bueno, ya tengo localizados los LED's. Step by step.
Editado por vanquish, 23 marzo 2013 - 10:44:45.
Escrito 23 marzo 2013 - 10:51:04
Me queda la duda sobre el relé. Intuyo que será necesario, pero no lo sé seguro. Ni sé qué relé ni dónde está.Pero bueno, ya tengo localizados los LED's. Step by step.
Bien! A ver cómo queda!
Escrito 23 marzo 2013 - 18:05:45
Mas...a falta del manual del coche (grrrrrrrrrrrrrrrrrrrrr) he encontrado este esquema de la caja de fusibles. Es el número 24 (de 7.5 amperios). ¿Alguien con conocimientos de electricidad podría indicarme el amperaje para poner esto los leds que indiqué antes?
PD: juro solemnemente que un día pararé de toquetear el coche...
PD2: bueno, pues finalmente las he comprado tras comprobar que funcionan con los voltajes correctos. 25 euros envío incluido los 2 leds para el plafón interior y otro para el maletero.
Editado por vanquish, 23 marzo 2013 - 18:41:53.
Escrito 23 marzo 2013 - 18:30:04
Escrito 06 abril 2013 - 20:01:54
El día que lo vendas? :D:D:D:D
Calla, eso no lo digas ni en broma!!
Pues esta misma tarde los he montado. 2 minutos he tardado y me ha sobrado para casi cargarme uno...pero por lo demás, luz más blanca y en general mejor iluminación. A ver si hago alguna foto un día de estos.
Próxima parada...detallado exterior...pero eso será dentro de un tiempo.
PD: he comprado un limpiador para las llanta que parece que tiene buena pinta. Seguiremos informando.
Escrito 20 noviembre 2017 - 16:18:07
Y la foto?
Me estoy animando a cambiar las luces de la famosa dome (DE3022):
https://www.s2ki.com...5/#post14405286
Ya que me quiero poner con las del portamatrículas trasero.
