![Foto](https://clubhondaspirit.com/foro/uploads/profile/av-694.jpg?_r=0)
Igual un poco cantoso (link)
Escrito 16 agosto 2005 - 15:52:10
en la pagina de Jtuned en la seccion "statics" hay unos cuantos civics bastante bonitos, ala, a disfrutarlos.
Escrito 16 agosto 2005 - 16:34:57
Escrito 16 agosto 2005 - 22:56:28
![:)](http://clubhondaspirit.com/foro/public/style_emoticons/default/smile.gif)
Escrito 17 agosto 2005 - 22:33:55
Escrito 17 agosto 2005 - 22:41:25
Escrito 17 agosto 2005 - 23:32:36
fijaros lo que lleva:
Type R cylinder head
Portflow reworked: ss valves, ti. Retainers, dual valve springs, 84mm combustion chamber
ARP headstuds
TOP FUEL turbo spec’d cams
JUN cam gears
TODA timing belt
Type R valve cover
FEEL’S oil cap
BACKYARD SPECIAL carbon Kevlar plug cover
RPM Service 72-70mm también
JG EDELBROCK intake manifold
HONDATA intake manifold gasket
OEM Honda B20 headgasket
CUSCO 15mm oil catch tank
B20B BENSON’s ductile sleeves w/ copper o-rings
CROWER rods
JE 9.0:1 pistons
BLITZ oil sandwich adaptor
MUGEN baffled oil pan
SPOON magnetic drain plugs
TODA oil pump gear
Honda CTR N1 crank pulley
BLITZ SBC-ID boost controller
HKS GT3240 turbo
HKS GTII 60mm wasetegate
HKS T51R air suction funnel or BLITZ SUS filter
TSR custom stainless exhaust manifold
TSR custom 3” downpipe
TSR custom wastegate dump
TOP FUEL 3.25” turbo cat back exhaust system
TSR custom anodized i/c brace
BLITZ 3 row i/c
HKS Type II Racing BOV
SP ENGINEERING aluminum piping
SP ENGINEERING hump hoses
TURBONETICS T-bolt clamps
FLUIDYNE radiator
SPAL electric fan
TYPE R water pump
CSR coolant overflow tank
Aluminum coolant breather tank
BLITZ coolant reservoir
SPOON radiator stay w/ titanium bolt
MUGEN fan switch
MUGEN thermostat
BLITZ cooling performer
HKS radiator cap
MUGEN motor mount kit
PROTHANE mount insert kit
CTR aluminum a/c motor mount
J’s RACING engine torque damper
BLITZ 1000cc injectors
ADF fuel rail
SX fpr
SX fuel pump
SX fuel filter
8 aluminum hardline
EARL’s -8 pro-light fuel lines
NGK V-Power plugs
BLITZ spark performer
MSD Blaster
MSD Pro Cap
MSD Digital 6-Plus ignition
HKS F-CON V-PRO Ver. 3.2: JASON & HIRO
LS transmission w/ GS-R 5th and final drive
OS GIKEN twin plate clutch w/ flywheel
KAAZ 1.5 way LSD
Scatter shield
DRIVE SHAFT SHOP 36mm stage 5 axles
SPOON drain plugs
![:blink:](http://clubhondaspirit.com/foro/public/style_emoticons/default/blink.gif)
Escrito 18 agosto 2005 - 00:01:33
Escrito 18 agosto 2005 - 00:05:22
Escrito 18 agosto 2005 - 01:39:22
Escrito 18 agosto 2005 - 01:56:47
Escrito 18 agosto 2005 - 12:36:20
![:oops:](http://clubhondaspirit.com/foro/public/style_emoticons/default/blush.gif)
