Accionar la Capota en Marcha y Sin Freno de Mano
19 respuestas en este tema
#1 Storm
  • 12.367 mensajes
Escrito 05 mayo 2020 - 06:06:34
Muy buenas,
Ayer hicimos ésto:
https://modifry.com/.../top_bypass.htm
Más ésto:
https://www.s2ki.com...e5/#post5882677
Ok guys, I have big news about this thread, because I have done this mod now, and I can tell you that what ruexp67 said about cutting the green/white wire is valid, the BRAKE light in the cluster will still operate normally this way.
When you ground the remaining wire going into the soft top controller, you are telling it that the e-brake is always on, but the rest of the car does not know that when the wire is cut. So there is no need for a switch or anything like that.
To recap, you cut the green/white wire and ground the part going into the soft top controller (there are 2 black ground wires conveniently on the same plug that you can tap it into). The part that is going back into the car, you just let hang, or insulate if you feel necessary. As long as this part is not grounded the BRAKE light will not stay on, yet works as usual with the pulling of the e-brake.
This is a relief to me, because one clicking the e-brake and/or installing a switch was too much for me, I was prepared to lose the functionality of the BRAKE light in the cluster just to have this mod fully work, but am overjoyed that it works with no adverse affects...
Como la seda. :chino:
P.D: Todo aquí:
http://viviendoapesa...da-s2000-2.html
#2 epsylon8
epsylon8
  • 1.946 mensajes
Escrito 05 mayo 2020 - 21:57:02
Buen trabajo.
Editado por epsylon8, 05 mayo 2020 - 21:57:22.
#3 Storm
  • 12.367 mensajes
Escrito 06 mayo 2020 - 10:40:00
Buen trabajo.
Gracias. Mi hermano es un crack. :chino:
#4 Gerinski
Gerinski
  • 3.185 mensajes
Escrito 11 mayo 2020 - 13:33:30
Felicidades por la mod, yo igual se la hago también algún día de éstos.
#5 Storm
  • 12.367 mensajes
Escrito 11 mayo 2020 - 14:54:01
Así es como debería de funcionar de serie para que lo usemos con SENTIDO COMÚN.
ODIO los mecanismos y limitaciones que tratan al usuario como si fuese IDIOTA.
#6 salsk8
salsk8
  • 614 mensajes
  • Coche:Honda S2000
Escrito 12 mayo 2020 - 08:12:28
El problema es que EL SENTIDO COMUN es el MENOS COMUN en la gran mayoria, y para evitar reclamaciones de clientes que se les ha roto la capota, mejor hacer las cosas para IDIOTAS. Así les sale más barato
#7 Gerinski
Gerinski
  • 3.185 mensajes
Escrito 12 mayo 2020 - 09:56:15
Sí, en parte es lógico que de serie lleve un sistema de protección así. En los cabrios modernos también lo llevan, por ejemplo si vas a más de 20 km/h el motor para abrir o cerrar la capota no funciona. En época del S el control por velocidad seguramente no era tan corriente y se decidieron por lo fácil, freno de mano puesto y punto.
#8 Storm
  • 12.367 mensajes
Escrito 12 mayo 2020 - 10:57:16
Estoy de acuerdo pero es ABSURDO tener que estar parado y con el freno de mano puesto para accionar la capota:
Circulando entre semáforos, por ejemplo, no debería de haber NINGÚN problema para poder poner o quitar la capota en caso de necesidad. :chino:
P.D: Gerinski, el S2000 controla las dos cosas. El coche debe estar parado (de ahí que se corte el cable de la señal de velocidad que le llega al módulo de control de la capota) y el freno de mano accionado mínimo un click (de ahí que engañemos al citado módulo para que se crea que el freno de mano va siempre echado).
#9 fabianD16
fabianD16
  • 289 mensajes
  • Coche:civic 1.6ies (MB4)
Escrito 12 mayo 2020 - 12:57:47
No veo la utilidad de accionarlo en marcha.
#10 Storm
  • 12.367 mensajes
Escrito 12 mayo 2020 - 14:06:34
Supongo que tampoco la inutilidad de no poder hacerlo. :P
Editado por Storm, 12 mayo 2020 - 19:15:30.
#11 Kullman
Kullman
  • 2.270 mensajes
  • Coche:Uno coreano :_(
Escrito 12 mayo 2020 - 21:30:39
El único inconveniente que puede existir es que abras el techo por error, pero imagino que tendrá unos seguros que, de estar cerrados, no permitirán que se abra.
Yo si veo una ventaja, que es la de accionar el techo mientras estas buscando aparcamiento, o incluso para hacerlo en parado (en un semáforo, por ejemplo) sin tener que accionar el freno de mano.
#12 fabianD16
fabianD16
  • 289 mensajes
Escrito 12 mayo 2020 - 23:14:25
Si no tubiese los cierres de seguridad manuales todabia.
#13 epsylon8
epsylon8
  • 1.946 mensajes
Escrito 13 mayo 2020 - 08:55:22
Pues yo si le veo una ventaja a esa opción y es la de que vas por una carretera comarcal descapotado y derrepente se echa a llover y tan solo con aminorar la velocidad pones la capota sin la necesidad de andar buscando un sitio donde parar.
#14 Storm
  • 12.367 mensajes
Escrito 01 enero 2021 - 00:33:12
O, como ayer. Circulando a través de pueblos y poniendo y quitando la capota según chispea más o menos. Una gozada sin tener que andar pensando dónde parar a echar el freno de mano. :boing:
#15 Storm
  • 12.367 mensajes
Escrito 03 junio 2022 - 12:54:33
Mola y lo sigo usando. :chino:
Por cierto:
https://www.maserati...elos/mc20-cielo
https://maserati.sce...lay_desktop.mp4
https://maserati.sce...rse_desktop.mp4
Editado por Storm, 03 junio 2022 - 13:01:22.
#16 Filigranas
Filigranas
  • 1.578 mensajes
Escrito 07 junio 2022 - 13:49:58
buena mod, pero vas a dejar la capota mas cedida que el ogt de los presentadores telecirqueros :payaso: :yepa:
#17 Storm
  • 12.367 mensajes
Escrito 07 junio 2022 - 14:46:48
Por qué... si la uso... :P
...como debe ser?!? :meparto:
Editado por Storm, 07 junio 2022 - 14:47:51.
#18 Filigranas
Filigranas
  • 1.578 mensajes
Escrito 08 junio 2022 - 18:56:11
De accionarla con el coche circulando hombre
#19 Storm
  • 12.367 mensajes
Escrito 08 junio 2022 - 20:20:03
Sí, pero... :P
...DESPACIO. :meparto:
#20 Filigranas
Filigranas
  • 1.578 mensajes
Escrito 23 junio 2022 - 20:04:41
Sí, pero... :P
Despacio, solo la puntita=? :meparto:
