Bolt on Kraftwerks Supercharger Package
7 respuestas en este tema
#1 Storm
  • 12.339 mensajes
Escrito 18 mayo 2021 - 15:54:07
Muy buenas,
Acabo de toparme con el video:
https://kraftwerksus...50-05-3004.html
04-05 Honda S2000 Supercharger System w/o Tuning Solution
150-05-3004
Kraftwerks USA is pleased to introduce the newly redesigned supercharger system for the 04-05 Honda S2000.
Centered around the highly efficient Rotrex C38-81 Supercharger, the Kraftwerks Supercharger kit produces impressive results throughout the entire power band. While unlike any other forced induction system, the Kraftwerks supercharger system provides a linear power curve, torque on demand, cooler operating temperatures, and total drivability. The Kraftwerks supercharger system provides instant throttle response and a progressive power curve that increases all the way to redline without the typical 'spiking' or 'surging' associated with turbochargers. This unique, more usable power curve results in reduced cylinder pressures, less strain on engine components, and increased reliability.
Rotrex superchargers also operate much cooler when compared to turbochargers and other supercharger systems, which reduces the engine’s intake air temperature as well as its risk of detonation. Rotrex superchargers are renowned for their compact size, high adiabatic efficiency, low vibration, and quiet operation. Their unique traction drive technology is what makes all of this possible, which, unlike other superchargers, transmits power through frictional forces between its rolling elements. Each Rotrex unit features its own self-contained oiling system that remains independent of the engine. Its dual-action oil pump supplies traction fluid to the supercharger while the supplied cooler ensures proper fluid temperatures at all times.
Like all Kraftwerks supercharger systems, the S2000 supercharger system includes all the necessary brackets, and hardware for a simple bolt-on installation.
FEATURES & BENEFITS:
400whp/ 260 lb.ft. Through Skunk2 Header and Exhaust
Retains Factory A/C and Accessories
Grams Performance & Design 1,000cc Injectors
Plug & Play Injector Connectors
Grams Performance & Design 320lph High Flow Fuel Pump
Rotrex C38-81 Supercharger w/ 90mm Pulley (12.5psi)
NEW 30mm Drive Belt (10mm Wider Than Previous Generation)
Independent Cogged Drive System for Zero Slip
Front Mount Intercooler (24 x 12 x 3 inch)
Aluminum Intercooler Piping
Oil Cooler
High-Quality CNC-Machined Brackets and Idler Pulley
High-Quality Fasteners and Hardware
Recirculating Bypass Valve
Simple Bolt-On Installation - No cutting, Drilling, or Welding
* Upgraded Clutch Recommended
Extra:
:chino:
Editado por Storm, 18 mayo 2021 - 15:54:34.
#2 stifler_R
stifler_R
    Patxi
  • 1.773 mensajes
  • Coche:EK1, MB3
Escrito 18 mayo 2021 - 21:20:44
Esto ya tiene su tiempillo, me suena que es el que llevaba el chico del S2000 rojo ancho
#3 Storm
  • 12.339 mensajes
Escrito 19 mayo 2021 - 11:24:58
Sí, claro. No lo sacaron ayer. :P
Lo que, para mí, es nuevo son los videos de montaje en media hora. FLIPO. :meparto:
:chino:
#4 Yayo
  • 44.506 mensajes
Escrito 19 mayo 2021 - 14:35:39
De verdad os hace falta una poya más grande? lo importante es que la que tenéis se empalme, y cualquier S2000 de serie lo consigue...
Mirad que luego es tan grande y pesada, y no hay coxones de levantarla...XD
#5 stifler_R
stifler_R
    Patxi
  • 1.773 mensajes
  • Coche:EK1, MB3
Escrito 19 mayo 2021 - 16:50:21
Mirad que luego es tan grande y pesada, y no hay coxones de levantarla... XD
Te lo presento desde otro enfoque, yo cuando voy al buffet mi objetivo es reventar XD
#6 Yayo
  • 44.506 mensajes
Escrito 20 mayo 2021 - 01:58:41
Jjej
#7 torralba
torralba
  • 248 mensajes
  • Coche:honda s2000
Escrito 22 mayo 2021 - 16:33:30
Ese video, son unos maquinas, ojala hubiera gente así de los de lht aqui en España, parece que meterles ahí el kit y reprogramarlo, es como un cambio de aceite.
A mi si me molaria ponerle uno.
#8 Storm
  • 12.339 mensajes
Escrito 22 mayo 2021 - 21:18:17
Gra... :P cias. :meparto:
