Restauración (Pulido) de Llantas con Corte por Diamante
18 respuestas en este tema
  • 12.798 mensajes
Muy buenas,
En su momento me hablaron del tema, cuando estuvimos hablando de pintar un juego en bronce (https://clubhondaspi...dios-en-bronce/), pero como no tenía intención de tocar las originales, no le hice mucho caso.
El caso es que llevo tiempo con las famosas manchas blancas bajo el barniz original...
https://www.diamonda...diamond-alloys/
Corrosion to alloys wheels can easily happen and will result in your alloys looking damaged, worn and undesirable. Corrosion damage can start from a minor scrape or from a small gravel chip which breaches the protective lacquered layer on your rim allowing water to gain access to the metal. This process of corrosion is encouraged by the increasing amount of salt being spread on the roads during cold and frosty days to prevent cars and other vehicles from skidding. Corrosion is more apparent during the winter months because while dry salt has little effect on exposed metal, as soon as it becomes moist or wet it turns into an electrolyte and allows the passage of a small electrical current that combined with the salts causes a chemical change to occur resulting in corrosion and staining. Deterioration will continue as blisters increase in number and grow in size to form pits in the surface. At the same time the protective finish to the wheel will peel off as the effect of the corrosion spreads. These blemishes look like darkened areas beneath the protective layer with white powdery deposits on areas where the protection has completely failed.
... y como parece que van a mandar una de las llantas plateadas a retocar a Portugal, estoy pensando en mandar las 4 y dejarlas nuevas.
Alguno conoce el proceso y tiene experiencia con el tema, por favor? Muchas gracias. :chino:
Edit: Me sonaba:
Lo hacían con unas llantas de pre en Wheeler Dealers.
Editado por Storm, 03 diciembre 2024 - 01:53:55.
  • 12.798 mensajes
...estoy pensando en mandar las 4 y dejarlas nuevas.
Ayer las preparamos (sin neumáticos, válvulas, tapas ni plomos) para mandar. :chino:
epsylon8
epsylon8
  • 1.965 mensajes
Ojo que no todos los Portugueses trabajan igual.
Asegúrese de mandarlas al más fino.
  • 12.798 mensajes
Le entiendo pero no soy yo el que las manda sino Redline. Y es con quien trabajan habitualmente. :P
Espero que por algo. :meparto:
P.D: Ayer estuve mirando bien las llantas y sacando fotos y están bastante feas. :uff:
Editado por Storm, 05 octubre 2021 - 12:28:26.
aran01
aran01
  • 100 mensajes
Pues si te enteras de a cuál empresa las mandan y el resultado es bueno, dame info, porque yo tengo las mías con algunos roces y manchas de alquitrán que no hay quien quite
  • 12.798 mensajes
Ya deben estar de vuelta. :P
A ver si esta semana me entregan el coche. :meparto:
  • 12.798 mensajes
Ayer. :uff:
Bueno, las llantas han quedado NUEVAS. :P
Tanto que, ahora, las tapas quedan en evidencia. :meparto:
He estado pensando en pedir tapas nuevas pero voy a esperar a otras cosas que tienen más prioridad.
P.D: Me dicen que las ha hecho el portugués que empezó todo el rollo de las llantas (ahora debe haber muchos más) y que sólo trabaja con talleres (no particulares). :chino:
Editado por Storm, 18 noviembre 2021 - 22:09:02.
  • 12.798 mensajes
Acabo de pedir precio. :P
Soy LO PEOR. :meparto:
Edit: 56€ + IVA cada. :uff:
Editado por Storm, 19 noviembre 2021 - 11:33:07.
  • 38.212 mensajes
seguro que en aliexxpress esas tapas cuestan 5,6€ las cuatro XD
  • 12.798 mensajes
Puede ser pero... :P
...las voy a montar así mismo después de haberlas lavado con agua, jabón y mimitos del señor Storm. :meparto:
  • 12.798 mensajes
Hecho:
:chino:
Raytrance
Raytrance
  • 690 mensajes
Cawen!!!
  • 12.798 mensajes
Cawen!!!
Vaya... :uff:
Yo suelo lijar con papel para disimular. :chino:
  • 12.798 mensajes
Hecho:
:chino:
350€. :chino:
Filigranas
Filigranas
  • 1.578 mensajes
esta impecable el coche!
  • 12.798 mensajes
Están IMPRESIONANTES. :P
A ver cuándo les monto neumáticos en condiciones. :meparto:
Y yo lo he hecho con las llantas más bonitas del re. :chino:
Editado por Storm, 03 diciembre 2024 - 01:51:53.
  • 12.798 mensajes
Neumáticos all season de camino y acaba de aparecer el juego de tuercas plateadas con sus antirrobo. :chino:
Editado por Storm, 03 diciembre 2024 - 01:51:40.
  • 12.798 mensajes
En breves las calzo para invierno:
https://clubhondaspi...7/#entry2460207
:chino:
  • 12.798 mensajes
:chino:
Impresionantes:
https://clubhondaspi...82#entry2473907
:chino:
Editado por Storm, 11 abril 2026 - 00:31:54.
