U4GM: Last Epoch Chakram Build Guide: Maximize Your Damage
#1 Smsnaker235
Smsnaker235
  • Miembros L
  • 4 mensajes
  • Coche:the ford
Escrito 15 julio 2025 - 09:08:44
The Sentinel class in Last Epoch boasts a diverse array of powerful skills, but few offer the satisfying visual spectacle and raw damage potential of the Chakram. This unique throwing skill, exclusive to the Forge Guard mastery, allows you to unleash a flurry of spinning blades that pierce and bounce through enemies, cleaving through packs and bosses alike Last Epoch Gold.
Supporting Skills for Maximum Impact
To enhance your Chakram onslaught, it is advisable to utilize a combination of defensive and offensive buffs:
Manifest Armor: This is a formidable minion that serves both defensive and offensive purposes. Fully specialize it for durability and fire damage to absorb hits and align with your fiery theme. It can attract enemy attention, enabling you to safely deploy your Chakrams.
Ring of Shields: This skill provides exceptional layered defense through block chance and damage reduction. Additionally, it offers valuable utility by drawing enemies closer when you need to group them for optimal Chakram bounces.
Sigils of Hope: An essential component for any Sentinel, Sigils deliver a stacking damage buff and generate wards, significantly enhancing your overall DPS. Ensure they remain active as much as possible.
Forge Strike: Although it is not a primary damage skill, it is beneficial for generating additional minions if you have invested in minion summoning nodes within its skill tree, or it can simply serve as a utility skill.
Passive Tree: Forging a Path to Power
Your passive points will be spread across the base Sentinel tree and heavily into the Forge Guard mastery.
Sentinel Tree: Prioritize general offensive nodes like Devotion, Fearless, and Armour Clad for damage and survivability. Mana efficiency nodes are also useful early on.
Forge Guard Tree: Here's where the magic happens. Focus on Forge Guard's Call (more minion health/damage), Battle Hardened (physical/fire damage), Molten Blade (fire penetration), and Steel Aegis (block chance and effectiveness). Any nodes that boost fire damage, critical strike chance, or minion effectiveness will be highly beneficial buy Last Epoch Gold.
This Chakram build transforms your Forge Guard into a master of destructive, spinning blades. With careful skill node allocation, strategic passive choices, and smart gear choices, you'll be bouncing your way through the toughest content Eterra has to offer, turning every encounter into a fiery, blade-filled spectacle.
