que os parece????
5 respuestas en este tema
brtncivic
brtncivic
  • 730 mensajes
  • Coche:civic
queria saber opiniones sobre este aparato.
You've modified your Naturally Aspirated vehicle, now give it the extra fuel it needs. To make that combination of intake, header, exhaust, cams, headwork, etc. run at peak efficiency, you may need more fuel than the stock ECU can deliver. PowerCard is a unique, load based fuel adder which works with the factory ECU. PowerCard's simple push button interface and powerful load based technology render complex table based throttle position/RPM re-mapping systems a thing of the past.
PowerCard has three different modes which correspond to different performance parameters:
Low Load (Cruise) Fuel - is for light load situations, cruising or very light acceleration.
Transition Fuel - This is when you transition from low load to real acceleration and need a proper shot of fuel for the sudden change in load.
High Load Fuel - This is where you are asking for sustained and maximum acceleration or top speed performance.
PowerCard works independently of throttle position and RPM, which are not reliable indicators of load. By looking at duty cycle instead, PowerCard can be tailored to your Miata's specific need. Both the transition points between modes, and total fuel added in each mode, are cockpit adjustable while you drive. PowerCard is perfecto for tuning styles from "butt dyno" to speed shop rolling roads.
Just as driving styles differ, no two Miatas are exactly the same. That is why PowerCard is such a powerful and flexible tuning tool. It allows you, the user, to program when and where additional fuel will be delivered. Not emissions legal.
cuesta 200$ no esta mal no????
iosu
iosu
  • 1.305 mensajes
  • Interests:mi hijo
  • Coche:CTR
ostia nen tiene buena pinta, si lo que dice es cierto.
xilenzeVTEC
xilenzeVTEC
  • 4.116 mensajes
  • Interests:Yo y mi maquina Japo en un agujero urbano en medio de Madrid.
  • Coche:Civic coupe SR Vtec
¿ Te viene el ''PANG 3''? :P
NAVARRO_Si
NAVARRO_Si
    COUPE´s TEAMCEPO #01#
  • 6.626 mensajes
No tiene mala pinta, la misma pantalla te indica la mezcla de air/fuel no??
Y tiene para grabar 3 modos de conducción, para no ir siempre gastando gasolina de más.
Lo bueno de esto que a lo mejor sin ir al banco de potencia podemos regularlo, yo por ejemplo vivo a muchísimos kilometros de un banco para regular un apexi por ejemplo, además de que si modificas algo importante debes regularlo otra vez.
Y si lo venden los de jacksonracing debe valer para algo.
Haber si conseguimos mas información......
Editado por NAVARRO_Si, 19 marzo 2006 - 22:47:46.
xilenzeVTEC
xilenzeVTEC
  • 4.116 mensajes
Hombre si lo vende Jackson Racing no creo que sea malo. Ummmm <_< habra que informarse si señor.
NAVARRO_Si
NAVARRO_Si
  • 6.626 mensajes
Investigando por ahí y hablando con kike parece ser similar al safc de apexi :oops:
Osea un vacf pero sin poder adelantar VTEC.
Osea...... merece la pena pillar un apexi vacf :lol:
