Programar llave del accord
39 respuestas en este tema
#1 skiper
skiper
    SkiPeR
  • 3.550 mensajes
  • Coche:204CV
Escrito 29 junio 2006 - 22:55:19
no se si serviara, dice que es para el tsx
la utilidad? que is te kedas sin llaves, te la compras por ebay e la programas tu
que la de honda valdra un huevo
Programming:
The immobilizer that is now in your Accord key is already programmed to the car and should start your car without any further setup. The keyless entry remote is another issue. Programming it is really quite easy.
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps. Make sure the doors and the hatch are closed.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver under the audio unit.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver under the audio unit.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 1 to 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver under the audio unit.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 1 to 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver under the audio unit.
12. YOU SHOULD NOW HAVE HEARD THE SOUND OF THE DOOR LOCK ACTUATORS! Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 10 sec., aim any remaining transmitters (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored. (OPTIONAL)
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation of the transmitters.
The above programming instructions are directly from the Helms Acura TSX Service Manual.
Editado por skiper, 29 junio 2006 - 23:01:46.
#2 Yayo
  • 44.659 mensajes
Escrito 29 junio 2006 - 23:04:54
Yo creo que publiqué algo parecido, para resetear la centralita, también de un TSX, a petición de JAM. LA traducción era más o menos esta:
Te paso las instrucciones para resetear. Debes seguirlas al pie de la letra.
«Instrucciones para resetear:
- Introduzca la llave en el contacto mientras se toca los güevos con la mano izquierda.
- Apriete firmamente los dientes y, a la vez, y fuertemente, sus coones, en intervalos de 2 segundos, durante otros 10.
- Gire la llave a la posición 1.
- Gire la llave a la posición 3 mientras se echa hacia delante un poco y se mete un dedo en el culo (utilice ULTRON para lubricar).
- Ahora gire la llave a la posición 2 mientras guiña el ojo (no hombre, ese no!, el de la cara....)
- Gire de nuevo la llave a la posición "Ignition" y vuelva a tocarse los güevos. Para ello, antes, sáquese el dedo del culo.
La centralita de su vehículo ha sido reseteada.
Nota. Si la falla se vuelve a repetir, repita los pasos indicados tres veces. Si existiera persistencia acuda a su concesionario autorizado para que la operación se la realice personal cualificado, pero no olvide que debe ser Ud. quien esté sentado al volante en todo momento.
La operación se le realizará gratuitamente, pues su vehículo está en garantía. No obstante, si insiste en que su concesionario resetee la centralita todas las semanas le recordamos que está autorizado a cobrarle (léase la directiva de garantía de su vehículo). Si tiene alguna duda o consulta llame al Servicio de Atención al Cliente Honda Ibérica, donde le atenderá una señorita. 686-324566 (coste de la llamada 9 euros minuto más iva)».
#3 Toledano
Toledano
  • 9.326 mensajes
  • Coche:Accord 2.0 GLP
Escrito 30 junio 2006 - 08:39:19
Me parece muy interesante, de hecho llevo tiempo pensando comprar una llave más de repuesto, ya me llevé un susto una vez.
#4 Toledano
Toledano
  • 9.326 mensajes
Escrito 28 julio 2006 - 17:15:03
He preguntado en el conce, la espada sin más cuesta doscientos y pico € ! la llave completa unos 300€
Alguien sabe de otra alternativa para comprar la llave sin mando? quiero tener una de repuesto solo para poder abrir el coche.
#5 Chalai
Chalai
    CHALAI - Accord TYPE-S Aprilia SMV 750 Dorsoduro
  • 1.742 mensajes
  • Coche:Accord 2.4 Type-S Gris Grafito Perlado
Escrito 28 julio 2006 - 17:41:53
Hablare con el chirizo de mi barrio, a ver en cuanto me deja una GANZÚA. Si el precio es bueno, organizo un Grupo de Compra, :lol:
#6 JAM
JAM
    Miembro viril
  • 6.571 mensajes
Escrito 28 julio 2006 - 17:59:48
Aqui hay algo, pero no se de nadie que les haya pedido :unsure: :
http://cgi.ebay.com/...74450QQtcZphoto
Salu22 :ok::ok:
#7 'Santmate'
'Santmate'
Escrito 29 julio 2006 - 01:51:20
Una pregunta muy importante y de vital importancia.
Imaginaros q tengo 4 llaves de honda accord.
2 de ellas las q venían con el coche y otras 2 +.
Podrían servirme xa algo? aunq sea el mando o algo así? contadme...
#8 Toledano
Toledano
  • 9.326 mensajes
Escrito 29 julio 2006 - 16:06:47
Salu22 :ok: :ok:
Algo es algo, pero tampoco es barato, además abria que ver donde grabarla y programarla.
#9 JAM
JAM
    Miembro viril
  • 6.571 mensajes
Escrito 31 julio 2006 - 08:26:22
Se pueden activar hasta un máximo de tres llaves en los Accord. Al activar la 4ª borras la activación de la 1ª.
Según dice, cuando la pagues y la recibas, te peoporcionan los datos del activador más cercano a tu domicilio para esas funciones. Tienen más de 10.000 colaboradores en todo el mundo.
Salu22 :ok::ok:
Editado por JAM, 31 julio 2006 - 08:27:57.
#10 Toledano
Toledano
  • 9.326 mensajes
Escrito 31 julio 2006 - 09:32:33
Ya lo he leido, pero no cuento que tengan en Madrid, pero además de activarla hay que grabar la espada, lo que es la forma de la llave, o eso lo puedo hacer en cualquier sitio?
#11 JAM
JAM
    Miembro viril
  • 6.571 mensajes
Escrito 31 julio 2006 - 09:46:44
No, se supone que en esos talleres deberían hacerla, a la vez que la activan. Yo ya he intentado conseguir una espada y ni en los mejores especialistas de Valencia he podido conseguirla, pero además me dicen que ni siquiera mecanizarla, si consiguiese la base.
Salu22 :ok::ok:
#12 Toledano
Toledano
  • 9.326 mensajes
Escrito 31 julio 2006 - 10:01:19
Salu22 :ok: :ok:
Chungo entonces, la verdad es que me gustaría conseguir una llave, ya tuve un problemilla en un viaje y no quisiera repetir la experiencia ...
#13 Diego
Diego
  • 17.985 mensajes
  • Coche:S2000 rojo Ascari
Escrito 31 julio 2006 - 10:19:57
A nosotros nos han fabricado juegos de llaves en estas dos empresas para los coches de la empresa:
CODYCER - 91 569 07 99
Codificacion DOVER - 91 304 56 40
Lo que no se es la cantidad de llaves que admite la centralita del Accord, en ese aspecto hay que ir con cuidado porque no suelen admitir mas de tres juegos. Algunos modelos no admiten mas de dos.
#14 Toledano
Toledano
  • 9.326 mensajes
Escrito 31 julio 2006 - 10:40:18
Gracias Diego, lo primeros se han trasladado 91 311 70 70 y no hacen ese tipo de copias, con los segundos estoy en marcha, les he mandado unas fotos de la espada a ver si podemos hacer algo.
#15 Diego
Diego
  • 17.985 mensajes
Escrito 31 julio 2006 - 10:46:14
Joer, gracias por la informacion. La verdad es que hacia tiempo que no trabajabamos con ellos. :oops:
#16 'Santmate'
'Santmate'
Escrito 31 julio 2006 - 13:04:07
Salu22 :ok::ok:
Pero es q las otras 2 llaves tienen espada diferente :oops: y no tienen el botón xa abrir el maletero.
sería programar el mando a distancia...
#17 JAM
JAM
    Miembro viril
  • 6.571 mensajes
Escrito 31 julio 2006 - 18:23:14
:blink: Pues si solo vale para abrir /cerrar puertas, no es que te pueda ser muy útil. La referencia del circuito tiene que ser la misma, de lo contrario las frecuencias no serán compatibles. La programación de la espada sirve para autorizar a la ECU el arranque con el transponder que lleve esa llave, pero no tiene nada que ver con el funcionamiento del mando a distancia.
Salu22 :ok::ok:
#18 'Santmate'
'Santmate'
Escrito 31 julio 2006 - 22:29:11
tonces no me vale para lo q tengo?
#19 Chalai
Chalai
  • 1.742 mensajes
Escrito 01 agosto 2006 - 02:15:49
Entiendo que si quiero hacer una llave sin mandos de puertas ni de maletero, osea una sencilla que poder llevarme a la playa y poder bañarme con ella...no puedo? :blink: Lo digo pq como hablais de circuitos interiores de la llave que lleva para el codigo lo mismo se fastidia con el agua. :unsure: Joer, pues es una pena. Con la vidilla que da el poder bañarte con la llave del coche... :roll: siempre y cuando no tengas que ir a buscarla al fondo del mar claro :oops: ]
#20 DocJones
DocJones
  • 1.580 mensajes
  • Coche:Kia Niro Emotion . Ex Accord 2.4 At.
Escrito 01 agosto 2006 - 09:20:27
y digo yo
no hay ningun parato que capture la frecuencia del mando de la llave , pudiendo hacer una copia del mando?.
es otra posibilidad para los que nos hemos dejado alguna vez la llave dentro , aunque claro , hay quien también se dejaria el mando dentro :) .
