SIX-IN-ONE GAUGE-TYPE UEGO CONTROLLER" www.aempower.com
- 24 Color-coded LED display lights provide immediate reference to engine's air/fuel ratio (AFR) or Lambda (11.0:1 to 17.0:1)
- Integrated three-digit display reveals AFR or Lambda in real time (10.0:1 to 18.5:1)
- User-selectable 0-5v analog output included for use with data loggers and most programmable engine management systems
- NEW! Switch between AFR or Lambda readout with a twist of a switch (included face plate change is required for proper readout)
- NEW! Included black and silver bezels, black and white AFR gauge faces and black Lambda gauge face allow you to personalize the look of your gauge!
- NEW! Quick-Connect system eases installation by allowing users to mount the gauge and sensor wiring separately
- Ideal AFR monitoring tool for carbureted applications and engine dynamometers
- Does not oscillate AFR like narrow band sensors
- Serial data stream included for output of AFR (RS 232)
- Accurate to 0.1 AFR
- Bosch UEGO sensor included
Editado por DeFiNiTiVo, 21 agosto 2006 - 14:36:58.
