A ver si ahora:
HONDA FAULT CODES
FAULT CODE IDENTIFICATION CIVIC 5 DOOR 1996, CIVIC D 1997 ONWARDS & ACCORD 4 DOOR
1996 -98 Petrol
Fault code Fault location
11 Open circuit in right hand front wheel speed sensor
12 Short circuit in right hand front wheel speed sensor
13 Open circuit in left hand front wheel speed sensor
14 Short circuit in left hand front wheel speed sensor
15 Open circuit right hand rear wheel speed sensor
16 Short circuit right hand rear wheel speed sensor
17 Open circuit left hand rear wheel speed sensor
18 Short circuit left hand rear wheel speed sensor
21 Damage to rotor teeth
31 Right hand front inlet, hydraulic modulator solenoid valve
32 Right hand front outlet, hydraulic modulator solenoid valve
33 Left hand front inlet, hydraulic modulator solenoid valve
34 Left hand front outlet, hydraulic modulator solenoid valve
35 Right hand rear inlet, hydraulic modulator solenoid valve
36 Right hand rear outlet, hydraulic modulator solenoid valve
37 Left hand rear inlet, hydraulic modulator solenoid valve
38 Left hand rear outlet, hydraulic modulator solenoid valve
51 The pump motor is locked
52 The pump motor is inoperative
53 The pump motor is constantly on
54 Inoperative relay
61 Low supply voltage
81 The combination control module or relay
Diesel
12 Self diagnosis-initiating
16 Left hand front inlet, hydraulic modulator solenoid valve
17 Right hand front inlet, hydraulic modulator solenoid valve
19 Relay of the hydraulic modulator solenoid valve
25 Damage to rotor teeth
26 Left hand rear inlet, hydraulic modulator solenoid valve
27 Right hand rear inlet, hydraulic modulator solenoid valve
28 Left hand front outlet, hydraulic modulator solenoid valve
29 Right hand front outlet, hydraulic modulator solenoid valve
31 Left hand rear outlet, hydraulic modulator solenoid valve
32 Right hand rear outlet, hydraulic modulator solenoid valve
35 The pump motor
37 The (BPP)Brake pedal position switch
39 Open circuit in the left front wheel speed sensor
41 Short circuit in the left front wheel speed sensor
42 Open circuit in right front wheel speed sensor
43 Short circuit in right front wheel speed sensor
44 Open circuit in left rear wheel speed sensor
45 Short circuit in left rear wheel speed sensor
46 Open circuit in right rear wheel speed sensor
47 Short circuit in right rear wheel speed sensor
48 Low supply voltage
55 The combination control module or relay
56 Operating error with fault code indication
CIVIC 5 DOOR 1995, ACCORD COUPE 1994-97, ACCORD AREODECK 1995-97
1 The hydraulic pump motor is over-run
1-2 The hydraulic pump motor
1-3 Is a high pressure leak
1-4 The pressure switch
1-8 Accumulator of high pressure system
2-1 Circuit of handbrake warning lamp switch
3-1 Rotor teeth damaged on right hand front wheel speed sensor
3-2 Rotor teeth damaged on left hand front wheel speed sensor
3-4 Rotor teeth damaged on right hand rear wheel speed sensor
3-8 Rotor teeth damaged on left hand rear wheel speed sensor
3-12 Combination of different sizes of tyres
4-1 Circuit of right hand front wheel speed sensor
4-2 Circuit of left hand front wheel speed sensor
4-4 Circuit of right hand rear wheel speed sensor
4-8 Circuit of left hand rear wheel speed sensor
5-4 Right hand rear wheel lock
5-8 Left hand rear wheel lock
6-1 Front fail safe relay
6-4 Rear fail safe relay
7-1 Right hand front, hydraulic modulator solenoid valve
7-2 Left hand front, hydraulic modulator solenoid valve
7-4 Rear, hydraulic modulator solenoid valve
8-1 Operation of the ABS
8-2 The ECU
8-4 Internal circuit of the ECU
							Editado por H_punto, 21 febrero 2007 - 21:38:33.
