EL LINK
http://www.ozhonda.c...ead.php?t=17777
me parece que, hay que apretar el auto y el dual a la vez y encender el coche, y soltarlos
After leafing through the 04/05 Service Manual, I came across a couple of diagnostic modes that you can enter without hooking the car up to the Honda Diagnostic System. I haven't tried this on mine yet (just got it a couple of days ago), but give it a try and let me know what you think...
From page 21-11 (Climate Control section):
The climate control unit has a diagnostic mode that allows you to view sensor inputs that it receives. To run the sensor input display mode:
1. Turn the ignition switch off.
2. Press and hold both AUTO and DUAL buttons, and start the engine.
3. After the engine starts, release both buttons.
4. The audio-HVAC display will flash a sensor number, then value for the sensor.
5. To adavnce to the next sensor, press the rear window defogger button.
6. To cancel this mode, press AUTO, or turn off ignition.
Sensor numbers, descriptions, and display values as follows:
1. In-car temp (degrees C).
2. Outside temp ©.
3. Solar radiation sensor value (00=dark, 10=cloudy, 65=sunny).
4. Engine coolant temp ©.
5. Evaporator outlet air temp ©.
6. Driver's air mix opening (low=cool, high=warm, %).
7. Passenger's air mix opening (low=cool, high=warm, %).
8. Vehicle speed (km/h).
9. Vent temp air out ©.
That's right - you have a digital speedo in your car!
MAS COSAS
Audio Unit Self-diagnostic Function
How to apply the self-diagnostic functions (without Navigation)
1. Turn the ignition switch to ACC (I) or ON (II).
2. While holding down the up of both ''REW'' and ''DISK+'' buttons simultaneously, press the power switch.
3. The following BUS communication DTC will appear on the sudio unit dispaly.
4. By turning on a switch while the DTC is displayed, the input will trigger the DTC mode that is assigned to that switch.
PLAY/PROG switch
Entire LCD lighting mode: Lighting the entire LCD to show the presence or absence of an LCD failiure.
NR switch
Entire LCD lights-out mode: Turning off the entire LCD to show the presence or absence of an LCD failure.
DISK+switch
Display I2C-BUS communication verification status: TO display the validity verification of the communication among the DISP, EEPROM and TUNER.
5. DTC mode will cancel when the audio main power switch is turned OFF or the ignition switch is turned OFF.
Display Specifications (without Navigation)
No. Verification items Verification results
1 Entire LCD lighting ———
2 Entire LCD lights-outs ———
3 I2C-BUS communication verification status DSP communication OK
4 DSP communication NG
5 EEPROM communication OK
6 EEPROM communication NG
7 TUNER communication OK
8 TUNER communication
Editado por skiper, 04 diciembre 2007 - 14:09:08.
