Bueno, casi que voy a abrir otro post como consecuencia del anterior y las preguntas de los kits de frenos movit...
El caso es que casi un mes despues de preguntarles por fin me contestan y me dicen lo siguente para los posibles interesados...
we can offer for your car following brake kits:
front: 17&18":
322x32 mm / 4m5 MONOBLOC @ € 2995.00 (your cost €2200.00) THIS ONE CAN BE MOUNTED WITH THE ORIGINAL 17" WHEELS!
342x34 mm / 4m6 MONOBLOC @ € 3595.00 (your cost €2700.00)
342x34 mm / 6s1 BILLET @ € 4825.00 (your cost €3400.00)
18&19":
370x35 mm / 4m6 MONOBLOC @ € 4625.00 (your cost €3231.79)
370x35 mm / 6s1 BILLET @ € 5895.00 (your cost €4228.15)
370x35 mm / 6s3 BILLET CERAMIC @ €10774.00 (your cost €7778.15) (weight reduction 5.4 kg on each wheel)
380x32 mm / 4m6 MONOBLOC @ € 4695.00 (your cost €3387.82)
380x32 mm / 6s1 BILLET @ € 6295.00 (your cost €4508.26)
380x34 mm / 6s3 BILLET CERAMIC @ €11412.00 (your cost €8258.26) (weight reduction 4.8 kg on each wheel)
19&20":
396x36 mm / 6s1 BILLET @ € 6695.00 (your cost €4788.38)
396x36 mm / 6s3 BILLET CERAMIC @ €12050.00 (your cost €8738.38) (weight reduction 5.6 kg on each wheel)
rear:
rr. 342x28 mm / 4m3b MONOBLOC @ € 3595.00 (your cost €2617.51 net.)
if you go for frt & rr upgrade i can offer you an additional 7.5% discount.
delivery time: approx. 3-4 weeks after order confirmation
shipping terms: ex works achern, germany
payment terms: 20% down-payment with order, rest when parts are ready for shipping
the brake kits include all needed parts as well as stainless steel lines for frt. & rr..
they can be installed by any serious shop or dealer, all needed parts are included.
the 6s1/ 6s3 BILLET CERAMIC calipers ensure the highest possible braking force, perfecto modulation ability
and absolut no loss of pedal feel even under high temperatures.
the above mentioned brake kits can be installed in any other car if you decide to sell your actual
one. so basically you buy the rotors and calipers only once and use them for the rest of your life.
Como tengo una empresa de importacion de accesorios estoy viendo si incluso se puede conseguir mas descuento...asi que tal vez me anime con el kit mas basico algun día de estos...pero de momento estoy recabando informacion y la comparto con vosotros...
Frenos Movit
hrcrothmans
, 13 junio 2009 10:15:20
