Par de apriete
11 respuestas en este tema
Natxete
Natxete
  • 1.015 mensajes
Hola, alguien sabe que par de apriete llevan nuestras ruedas? Con la llanta de serie del 2004 en adelante.
Lo digo porque ando mirando una atornilladora de impacto, o algo similar, y/o una dinamétrica tal vez.... vamos, algo que no tenga que darle a la palanca a mano.
Adri s2k
Adri s2k
    esedoska
  • 1.134 mensajes
  • Coche:Honda S2000
14kg o en su defecto 140 Newton ;)
  • 12.631 mensajes
http://www.s2ki.com/...for-wheel-nuts/
80 lb-ft
http://www.s2ki.com/...-caliper-bolts/
Just to confirm the Honda ESM says...
Caliper bracket - 32 N.m or 24 lbf.ft (front and rear)
n.b. This is the bolts that you undo when you want to change out the brake pads.
Wheel nut - 108 N.m or 79.6 lbf.ft
http://www.s2ki.com/...lug-nut-torque/
110 N-m (80 ft-lb)
http://www.ozhonda.c...bushing-install
Step 9: Put the wheels back on, lightly tighten the wheel nuts. Lower the car off the jack stands and torque the wheel nuts to around 110Nm.
http://www.s2ki.com/...valreplacement/
79.6 ft/lbs is what the manual recommends, but if I can quote Xviper: "I feel 80 is not quite enough and although 100 may still be safe, I compromise at 90. There have been reports of the odd owner here where the lugnuts loosened at 80."
Also: http://www.s2ki.com/.....&hl="Lug Nuts
90 is pretty much standard at the track whether it's Volvos or Ferraris. I've no idea why the first one went. It's possible that it was overtorqued past 90....I'd rather I made a mistake than there be some defect with Honda Lugs.
And yes, they're always tightened in a star pattern.
I'll link this thread--thanks Xviper!
Lectura interesante:
http://www.s2ki.com/...hl__%22Lug+Nuts
P.D: Al loro con pasarse!
http://clubhondaspir...ragos-en-s2000/
Editado por Storm, 22 marzo 2012 - 15:51:55.
Natxete
Natxete
  • 1.015 mensajes
Graaacias,
Y se le puede regular el par, verdad? O hay que comprar una que se ade 140 Nw por narices?
j0kiN
j0kiN
    JOkiN
  • 2.227 mensajes
  • Coche:S2000 / GOLF GTI MKII / CBR 125R
A una dinamometrica le puedes regular el par,logicamente.
Te recomiendo que compres mejor la dinamometrica en vez de la pistola de impacto.
Un saludo!!
Ivan84
Ivan84
  • 800 mensajes
  • Interests:coches,motos, vamos todo lo que tenga motor.
  • Coche:honda s2000 silverstone.
yo al mio le meto 12kl vamos 120 newton y va ya bastante bien luego cuando las vas a aflojar estan algo mas prietas.
Natxete
Natxete
  • 1.015 mensajes
Un saludo!!
Tomo nota, esta tarde la busco.
hrcrothmans
hrcrothmans
  • 650 mensajes
  • Interests:Correr en moto de circuito.
  • Coche:s2000
Yo compre la dinamometrica por ebay y por 40 euros las tienes mas que decentes para este menester...
deibit
deibit
  • 6.047 mensajes
  • Coche:MY08 Honda S2000
Si usas tuercas de aluminio, no las pongas a mucho mas de 110Nm (lo oficial son 108Nm como te indican mas arriba)
Y no uses la dinamométrica para aflojar.. Sobretodo si eres hardcore y eres de los que aflojan las tuercas con la rueda al aire (yo he reventado dinamométricas así) :). De todas maneras, don't do it at home (lo de aflojar tuercas con la rueda al aire)
La dinamométrica de 20€ va mejor que hacerlo a mano.. Pero cuenta que pueden tener error de unos 10Nm con respecto a las de 200€.. Y el par de apriete no es siempre consistente (a veces aprietan menos, a veces aprietan mas, a veces aprietan bien). Pero bueno, en cualquier caso, el error es aceptable, siempre que la fijes a unos 110Nm (mas que eso o menos que eso, es mas arriesgado por el error que tienen)
  • 7.946 mensajes
J@$~#R, que finos sois. Yo llevo toda la vida apretando las tuercas de las ruedas a ojo y ni me he cargado nunca una tuerca ni he pasado un espárrago. Y tampoco se me ha salido una rueda, claro.
  • 12.631 mensajes
Importante detalle éste último! Ja, ja, ja!!!
Yo me lo cargé por idiota. La verdad es que, si tienes un poco de tacto y costumbre, no hay mayor problema por hacerlo a mano pero si tienes un segundo juego de llantas y las cambias a menudo, te curas en salud.
hrcrothmans
hrcrothmans
  • 650 mensajes
  • Coche:s2000
efectivamente con un segundo juego de llantas cambias muchas veces las ruedas y si quieres hacerlo en casa y bien por 40 euros de dinamometrica te curas en salud y ademas te vale para apretar mas cosas :)
a mi me llamo la atencion lo flojas que estan las tuercas con su par correcto respecto a lo que solemos hacer " a ojo "... y sin embargo no se sueltan...ni en un trackday ;)
