Preparar un S2000 para TrackDays
#41
Escrito 12 noviembre 2022 - 21:23:28
#42
Escrito 16 noviembre 2022 - 23:12:32
#43
Escrito 19 diciembre 2022 - 16:17:39
P.S: 227,4 Cvs con un K24?!? ![]()
https://clubhondaspi...uestros-s2000s/
Editado por Storm, 19 diciembre 2022 - 20:16:56.
#44
Escrito 03 julio 2023 - 16:32:35
2006 Honda AP2 S2000:
Engine & Drivetrain
-CT engineering cold air intake
-Fujitsubo Legalis-R Exhaust
-Rainh8r valve cover mod
-Radium catch can
-Honda F22 Crate motor P&P Head
-AP1 JDM F20C forged pistons
-Hondata
-OSGiken 1.5 Way LSD, 4.3FD
-Koyo radiator
-Greddy Oil Cooler
-Billman TCT
Suspension
-JRZ RS Pro 2-Way w/ Remote Reservoirs
-Hyperco springs 16k/14k
-Hyperco helper springs
-Karcepts Front and Rear Sway Bar
-EVS Tuning Rear Bump Steer Kit
-Wicked Tuning Heim Spherical Bushings
-Wicked Rear Toe Arms
-J’s Racing S2 Front Roll Center Adjuster/Camber Joint
Brakes
-AP Racing 5000R Front Big Brake Kit
Wheels & Tires
-Volk TE37 Saga 17x10 +47
-Maxxis RC1 255/40/17
Body
-OEM Hardtop
-Front control arm Gusset plates (reinforce front upper control arm mount)
-Karcepts Rear Wheel Hubs
-Hasport Billet Differential Mounts
-Vibratechnic engine mounts
-Rcrew Roll Bar
-KSR hood vent
-ASM Fenders
-Amuse Legalo Front bumper
-Racebred Splitter and brackets
-Voltex Type 7 Swan Neck Wing 1600mm
Interior
-Recaro Jersey Red Pole Position
-PCI rails
-R1 Titan Shift Knob
-OMP Carbon 320s steering Wheel
-Works QR
#45
Escrito 13 octubre 2023 - 10:10:53
O para carreteras de montaña:
Mod List:
Engine/ Drivetrain:
Supertech valve springs and retainers
Top Fuel intake
High Flow Cat
Greddy SE Single exhaust
Ballade Throttle Body
Ballade Intake manifold
Ballade cams
Ballade Header
Toda timing Chain tensioner
AEM EMS
Tuned (220whp)
Koyo Radiator
Light weight flywheel
AP2 Secondary Gear
4.44 Final drive
Kaaz 1.5 way LSD
Axle Spacers
Yellow Box (Speedometer corrector)
Suspension/Wheels/Tires:
Ohlins DFV
J’s racing Ball joints
Eibach front sway bar
Full spherical bushings
CE28’s 17x9.5
RT660 255/40/17 Square
Brakes:
Buddy Club BBK
330mm rear rotors
Project Mu Club Racer pads
Interior:
Recaro Pole Positions *Jersey Red
Buddy Club rails
Recaro Side protectors
Elda Roll Bar
Momo Mod 78 *330mm
Works Bell Quick release
Evasive cruise control adapter
Exterior:
OEM lip
OEM side strakes
eBay rear spoiler (shaved to mount wing risers)
Alloy craft rear diffuser
Evasive rear bumper cap
AP2 tail lights
#46
Escrito 29 diciembre 2023 - 18:30:01
2008 Honda S2000 Mod List:
J's Type-GT Aero Kit
J's GT Spec Brake Duct Kit
J's GT Spec Canard Pair
J's GT Spec Fender Fence
Charge Speed Front Hood
Voltex Type 7.5 GT Swan Neck Wing - Chassis Mounted
K1 Laboratory Ducktail Spoiler
Seibon Carbon Fiber Trunk
Aerocatch Hood Latches / Mounting Plate
GT Motoring Tow Hook
M RACING Type 4 Aero Mirrors
AIM MXS Dash Display
AIM Solo 2 DL
AIM Smartycam HD 2.1
NASA/SCCA compliant roll cage w/ NASCAR driver's door bars
NRG Quick Release
Sparco 350mm Steering Wheel
Fire Bottle Safety System FE86 Fire Suppression System
STATUS CF Alcantara Seats
Nagisa Seat Rail - Driver
Buddyclub Seat Rail - Passenger
Sabelt Black 3" Belts
CF Center Console/Cluster
CR Shift knob
ScienceofSpeed Stage 2 Supercharger
ScienceofSpeed Big Bore Throttle Body
NGK Iridium
AEM Infinity Engine Management System
Single AEM inline UEGO wideband
Injector Dynamics 1050X
AEM Fuel Pressure Regulator (pre-set, do not adjust)
AEM Engine Oil Temperature Sensor/Oil Pressure Sensor/Fuel Pressure Sensor
Walbro 450 LPH fuel pump
ScienceofSpeed return fuel system
Radium R10A Radium Fuel Cell
Radium FCST
Radium Fuel Level Sender
Fuel Safe single point 2.5" probe dry break fuel filler
ScienceofSpeed Sport Plus Clutch Kit
Competition Clutch forged ultra lightweight flywheel
API clutch slave cylinder
Toda Oil Pan
Koyorad Oil Cooler
CSF Dual Pass Radiator
Custom Catch Can
Custom 3" exhaust system with 3" resonator and 3" mufflers, no cat
Advan GT & A052
JRZ RS PRO with 16kg Springs
Wisefab Front and Rear Suspension Drop Knuckle Kit
Puddymod Stage 2 Diff with OS Giken LSD 4.1 Gear
Origin Fabrication Upper Controll Mounting Point Gusset Kit
Splin Mota Rear Subframe Gussets
Spoon Rigid Collar Kit
Mugen Diff Mounts
Karcept Front/Rear Sway Bar
Stoptech Trophy Big Brake System (calipers: ST40 front, ST22 rear)
Carbotech XP 10 front (for ST40), XP8 rear (for ST22)
APR Extend Wheel Studs
#47
Escrito 06 enero 2024 - 18:40:58
Todavía menos. ![]()
#48
Escrito 16 enero 2024 - 11:17:30
#49
Escrito 22 febrero 2024 - 16:20:31
#50
Escrito 28 febrero 2024 - 00:02:29
MecagüenSatán! ![]()
P.D: Extra lap:
Editado por Storm, 28 febrero 2024 - 00:32:06.
#51
Escrito 01 abril 2024 - 12:24:21
#52
Escrito 04 abril 2024 - 04:52:14
#53
Escrito 09 junio 2024 - 22:46:11
Según he visto en redes sociales, el propietario de Talleres D&R de Badajoz, es poseedor de un S2000 K20 Swap Turbo
El trabajo ha sido hecho en Kaiten Sports (Portugal) y el coche sale de allí rumbo a Nurbur.
Especificaciones: Low budget ap1, k20a6 stock, gt3076, kpro 312cv 330nm, soplado 0,9 bares
https://www.instagra...zRlODBiNWFlZA==
#54
Escrito 21 marzo 2026 - 09:55:37
A mí me interesa el tema de los pesos:
https://clubhondaspi...-aligeramiento/
https://www.tegiwa.c...-s2000-cup-car/
https://www.tegiwa.c...arts-build-list
Honda S2000R Cup Master Build Kit
This package includes all the mandatory control parts that you need to build your Honda S2000 to regs for the Racing Hondas S2000 Cup.
The kit includes:
HR-6441: Hardrace Pillowball RC Tie Rod End
HR-6773: Hardrace Front Anti Bump Steer Kit
HR-6426-S: Hardrace Adjustable Rear Toe Control Arm with Spherical Bearings
HR-8512: Hardrace Adjustable Rear Upper Arm with Spherical Bearings
HR-6621: Hardrace Front Roll Centre Adjuster
KLC139: Whiteline Drop Link Stabiliser Adjustable Heavy Duty
BHF48: Whiteline Front ARB 30mm
YS01-HD-PC025: YSR Premium Competition Coilovers
32701-BH001: HKS Hi Power Single Exit Exhaust
UAC-FULLKIT-S2K: Tegiwa Front Splitter & Air Dam Kit
TEG-S2KREARWINGKIT: Tegiwa 1580mm Rear Wing Spoiler & Mount Kit
TGW-104: Tegiwa 10mm 4-piece Rear Driveshaft Spacers
TI4040011: Tegiwa Decat Pipe
MR162ZX17851245: Motegi MR162 Zentoku Alloy Wheel 17x8.5 ET45 5x114 Bronze x4
JN4-1215BK: JR JN4 Forged Wheel Nuts 12x1.5
HON-4-129: HEL Braided Brake Lines
S2000R-CAGE: S2000R Tegiwa SW Motorsports Weld-in Roll Cage
TEG-S2000-INTAKE: Tegiwa Air Intake
SWM-S2K-SEATBASE: SW Motorsports Super Low Bucket Seat Base Mount (Drivers Side)
Once you have purchased this kit then check out the S2000 Cup extras package to complete your build.
Editado por Storm, 21 marzo 2026 - 09:57:40.
#55
Escrito 29 marzo 2026 - 00:45:42
#56
Escrito 19 abril 2026 - 09:16:23
Guy Martin.
#57
Escrito 16 noviembre 2026 - 01:30:17
#58
Escrito 18 noviembre 2026 - 09:50:02
#59
Escrito 20 noviembre 2026 - 16:26:01
