Ferodo DS Performance S2000
64 respuestas en este tema
XaviPower
XaviPower
  • 1.430 mensajes
  • Coche:EXS2000 05' Black
Hoy he instalado las pastillas DS Performance en el eje delantero. Sustituyen a las OEM. El tren trasero sigue con las OEM. Todavía no hay prueba en carretera.
Salu2
Editado por XaviPower, 06 abril 2013 - 20:32:36.
Zzpancho
Zzpancho
  • 100 mensajes
  • Coche:Honda s2000
Tienen buena pinta, ya contaras que tal van..
  • 12.631 mensajes
Salu2
Interesante!
-Más info:
http://www.ferodo.co...erformance.aspx
While our Ferodo Premier pads are an international favourite, we also have a DS Performance line which is specifically designed for tuners and track day enthusiasts .
Delivering brake performance usually associated with the racetrack, these brake pads bring tuners all the benefit of our racing know-how and experience for daily use on the road. Ferodo DS Performance brake pads give both low and high speed braking efficiency, reduced stopping distances and great control.
You can be confident that our high performance brake pads undergo rigorous testing and development, from laboratory and dynamometer testing cycles to race circuit and road trials.
High performance tuning pads for the road
DS Performance pads are track day parts that bring racing technology to the road. These brake pads have a thermal under-layer between the friction material and the backing plate, to help dissipate heat during high speed braking. This prevents problems often associated with extreme conditions, such as overheating, damaged calliper seals and brake fade.
They also have excellent water recovery characteristics that allow you to regain optimum efficiency quickly - without losing control. Built-in anti-corrosive properties ensure there is no danger of brake seizure.
Driver safety
The braking system is critical to driver safety. Drivers should always operate their vehicle according to prevailing road conditions and adhere to any advisory or mandatory guidelines.
Quick-look benefits
    RACING-PERFORMANCE: Racetrack quality with European Union R90 road use homologation
    PROVEN: Rigorously tested on circuits and roads
    SAFE: Shorter stopping distances
    EASY: Simple to fit with all hardware included
-Comparativa con las DS2500:
http://www.forocepos...ead.php?t=52473
-Nuestro montaje de las Ferodo DS2500:
http://clubhondaspir...con-los-frenos/
Xavi, por qué te has decidido por las DS Performance? Por la frenada en frío, por no querer machacar los disco, porque no necesitas mucho más que lo que dan las OEM,...?
Editado por Storm, 07 abril 2013 - 09:45:34.
deibit
deibit
  • 6.047 mensajes
  • Coche:MY08 Honda S2000
Lo bueno de estas, es que son legales.
Adri s2k
Adri s2k
    esedoska
  • 1.134 mensajes
  • Coche:Honda S2000
Ponga unos latiguillos metálicos y un buen liquido :taptap:
Sobre las pastillas, ya nos dirá.
XaviPower
XaviPower
  • 1.430 mensajes
Interesante!
-Más info:
Por esas tres razones Storm :)
Todo a su tiempo ;)
  • 12.631 mensajes
Todo a su tiempo ;)
Ok, perfecto. Precio? Cuántos Kms tenían las pastillas que has retirado?
Bricos en camino! Espero que los hayamos hecho para cuando usted se decida.
Editado por Storm, 07 abril 2013 - 21:43:47.
hache28
hache28
  • 152 mensajes
  • Coche:s2000
Yo cambié mis pastillas delanteras de los Tarox este fin de semana, después hago un post.
De las pastillas que quité, que también eran Tarox, saqué la plaquita esa fina fina que venía con cada pastilla. Como las nuevas no traían plaquita pensé que no sería necesario. Debería poner la plaquita? La verdad que frena muy bien.
deibit
deibit
  • 6.047 mensajes
No "tienes" que usar la plaquita pero, yo siempre la re-uso.. la limpias, le pones un poco de pasta de cobre entre la plaquita y la pastilla y ya esta.
Ayuda a que las pastillas no hagan ruido y ademas hacen que el coche sea mas discreto, en mi caso las pastillas tienen una base metálica-dorada.
  • 12.631 mensajes
En mi caso las pastillas tienen una base metálica-dorada.
Truñero!
Ja, ja, ja!!!
deibit
deibit
  • 6.047 mensajes
Perdón, perdón no es metalica-dorada sino metalica-cobre (como unas llantas Volk, vamos) :lol:
  • 12.631 mensajes
Corre, Deibit, corre!
Ja, ja, ja!!!
hache28
hache28
  • 152 mensajes
  • Coche:s2000
Sois un pozo de sabiduría, la leche :)
XaviPower
XaviPower
  • 1.430 mensajes
Yo las plaquitas las volví a montar.....lo que no llevan y no se puede montar es el avisador acústico en las DS Performance. Bueno una vez probadas yo las veo igual que las OEM, quizá un tacto más agradable, pero en principio igual que las OEM
  • 12.631 mensajes
Y los chivatos?
http://clubhondaspir...s/#entry1744316
P.D: No son pastillas racing. Frenarán y sonarán (?) como unas OEM.
XaviPower
XaviPower
  • 1.430 mensajes
Y los chivatos?
En la caja rezaba "compuesto racing para uso en carretera" (vamos un injerto entre unas pastillas normales y unas racing :meparto: )....no chirrían si es a lo que te refieres....
Editado por XaviPower, 09 abril 2013 - 22:25:52.
deibit
deibit
  • 6.047 mensajes
Ferodo tiene otra gama "OEM-style" las DS Performance están entre esa gama y las DS2500.
XaviPower
XaviPower
  • 1.430 mensajes
Lo que si que he notado es que cuando haces un uso intensivo luego huelen a lo que yo llamo "radial cuando corta piedra" que es como huelen las racing.
_BoSS_
_BoSS_
  • 2.158 mensajes
  • Coche:Honda S2000 AP1 F20C
La gama que equivale a las OEM son las Ferodo Premier. Ayer monté un juego nuevo en el eje trasero. Para las delanteras tengo guardadas las Ds2500 para cuando se gasten las OEM... y sí, yo también puse las chapitas...
XaviPower
XaviPower
  • 1.430 mensajes
Sip.....tengo pendiente poner las Ferodo Premier en el eje trasero...estas si que llevan el chivato sonoro....
Salu2.
