The Theta Engine is the part of the series of engines created through a joint effort with Mitsubishi, Hyundai, and Chrysler, dubbed the "World" engine. The Theta block is very similar to the Mitsubishi Evolution X 411BT, but the two engines are not identical. The Theta block is built with some lower quality components to keep the cost down. Some areas of note are the pistons, rods, and lack of significant webbing on the block. As of the Spring of 2009, this engine is still very new and it's limits have yet to be fully explored
Traduciendo:
El bloque es similar al del evo 10, PERO esta construido con materiales de mas baja calidad para abaratar los costes. Algunas areas notables son pistones, bielas, y distinta construccion del bloque.
Vamos... que se puede decir que se "parece" pero lo mismo que se parece un zapato nike a uno nite.
o de los motores rover de honda... potenciar algunos de ellos, no dan el rendimiento que el "original" sinceramente, una cosa es tener los planos de algo, y otra muy distinta los materiales. Si no los rascacielos se construirian con barajas de naipes
