El mercado actual del S2000. Unidades en venta. Comentarios
3952 respuestas en este tema
#3881
epsylon8
epsylon8
  • 1,970 mensajes
Yo respeto que haya quien valore una tirada exclusiva , pero a efectos prácticos un CR no aporta nada.
Es posible que si mi S hubiera estado aparcado y pasará Ayrton senna a su lado y le apretará la vejiga y quedase contrastada la meada por una camara, que mi unidad valiese más que esos CR XD
Editado por epsylon8, 13 May 2025 - 00:24:35.
#3882
  • 12,910 mensajes
What?
https://en.wikipedia...r_(U.S._-_2008)
https://www.s2ki.com...erences-755380/
Model Year 2008 S2000CR
On August 15, 2007 Honda announced the addition of a club racer-inspired S2000 CR to the S2000 lineup. The S2000 CR (CR for "Club Racer") features are designed to appeal to enthusiasts who enjoy open track day events and also provide a more ideal starting point for racers who modify the S2000 for competition in club racing events.
This factory-tuned sports racer is lighter, stiffer and faster than the stock S2000. The S2000 CR has a much more aggressive look thanks to the aerodynamic body kit that features a front spoiler that wraps around the corners of the vehicle, rocker-panel extensions, a large rear wing and faired-in headrests. The car's handling has been made sharper with the use of quicker-ratio steering, firmer springs and shocks, sticky Bridgestone Potenza RE070 tires and larger-width rear wheels. Extra body stiffness comes from additional bracing attached to the storage area for the folding cloth top, which has been removed. In its place, buyers get a removable aluminum hardtop. This change also results in weight savings of about 90 pounds. The changes to improve the S2000's track times do not come at the expense of creature comfort. The CR can be equipped with optional air conditioning and an AM/FM stereo with CD player. The sport seats are clad in cloth with unique yellow stitching, and the interior is accented with carbon-fiber-style trim panels and a special aluminum shifter.
S2000 CR Exclusive Features:
• Firmer, track-oriented suspension settings for springs, dampers and stabilizer bars.
• Front coil springs 37% stiffer and rears 17% over 2008 standard model.
• Front damping force increased 50% and rears 32% over 2008 standard model.
• Front stabilizer bar (mm): was 26.5 x t4.5 in 2007 to 27.2 x t5.3 in 2008 and to 28.6 x t4.5 in S2000CR (+1.4 x -0.8).
• Rear stabilizer bar (mm): Rear: 25.4 x t4.5 in 2007, no change 2008 except for S2000CR to 26.5 x t4.5 (+1.1 x 0.0).
• Structural enhancements include rear body brace and steering gearbox brace
• Quicker steering ratio of 13.8:1 (compared to 14.9:1)
• More aggressive tires using ultra-high performance Bridgestone Potenza RE070 tires in place of RE050 tires; 215/45R17 front and 255/40R17 rear (a larger rear tire size by 10mm)
• Aerodynamic body kit for reduced coefficient of lift (Cl) and improved balance and reduce lift through large and specially-tuned front and rear spoilers. Lift is reduced by 70-80% depending on the roof configuration.
• Removable aluminum hardtop
• Sport muffler for a tuned exhaust note
• High-grip fabric seating surfaces with synthetic suede trim; black fabric seating surfaces with yellow stitching. Synthetic suede bolsters enhance lateral grip.
• Unique spherical aluminum shift knob rests 12.6 mm lower for a 6 percent reduction in shift stroke compared to the regular S2000 cylindrical shift knob (aluminum/leather wrapped). Additionally, shift load effort increases by 10 percent for even more direct feedback when engaging a gear.
• The S2000 CR instrument panel meters include a "peak-power indicator." When the engine is operating at peak power, a round, green light illuminates to the right of the digital speedometer.
• Omitted items for weight reduction: convertible soft top, audio system (optional factory install), air conditioning (optional factory install), spare tire and jack, and sound insulation. Relative to the base 2008 S2000, cumulative weight savings total 51 pounds (hardtop installed) and 99 pounds (hardtop removed).
• new wheel design in Kaiser Silver
• rear body brace has been added to the area previously occupied by the soft top, resulting in additional rigidity.
• Carbon fiber-style trim interior panels.
S2000 CR Weight Savings Summary
Eliminated components to save -51 pounds:
* Electrically-powered convertible soft top
* Sound insulation
* Spare tire and jack
Optional eliminated components to save -42 pounds:
* Air conditioning
* Audio system
User-Configurable components to save -48 pounds:
* Removable aluminum hardtop
Exclusive S2000CR components that added + 42 pounds:
* Front and rear spoiler
* Rear body brace
* Steering box brace
* Roll bar cowlings and hardtop mounting covers
* Heavier suspension components
* Increased rear tire size
* Tire repair kit
https://hondanews.co...cr-introduction
:uff:
Editado por Storm, 15 May 2025 - 13:11:33.
#3883
EDVTEC
EDVTEC
  • 558 mensajes
https://www.autoscou...utm_term=detail
Honda S 2000
S2000 2.0 VTEC
€ 23.999
130.000 km, 03/2008
Particular
 ES 36949 Cangas
#3884
epsylon8
epsylon8
  • 1,970 mensajes
What?
:uff:
Bueno , no se...pero a uno normal se le puede quitar la lona , la radio , el aire acondicionado y la rueda de repuesto.
Tmbn se pueden poner mejores suspensiónes , aligerar toda la linea de escape y poner estabilizadoras más rígidas así como refuerzos alerones o llantas más ligeras.
Editado por epsylon8, 16 May 2025 - 22:58:17.
#3885
  • 12,910 mensajes
Y, aún y todo... :P
...no llevaría las mismas mejoras que un CR. :meparto:
#3886
epsylon8
epsylon8
  • 1,970 mensajes
Y duro y dale...
Para mí el que no lleve capota de lona, radio o aire acondicionado no son mejoras ,son perjuicios.
Ni rueda de repuesto ni gato.
Como ha cambiado la vida , antiguamente el aire acondicionado o los asientos de cuero eran Extras.
En el año 1985 salió el Renault 5 GT Turbo.
Se celebraba el campeonato Copa Renault y la marca sacó una promoción para quien quisiera competir.
Esas unidades eran exactamente iguales a las de calle , solo que en vez de llevar llantas de aluminio las llevaban de chapa.
No llevaban ni radio ni antinieblas y la presión del turbo iba tarada un poco más alta.
Bien , pues eso lo que hacía era abaratar el producto para ayudar economicamente a quien quería iniciarse , aquí parece que lo han hecho al revés.
PD: esas unidades portaban el anagrama de COPA en el maletero y dado el entusiasmo y la admiración que generaba (presuponiendo la gente que era más bruto , cosa que no era cierta) la dirección optó por añadir el dichoso anagrama a todos los modelos a partir de 1987.
#3887
  • 12,910 mensajes
Y duro y dale...
Pues, entonces, dí que no te aporta nada A TI.
Obviamente, al que busca un CR (Club Racer), SÍ.
#3888
npulsar
npulsar
    F20C
  • 2,111 mensajes
  • Coche:...
Y duro y dale...
Es respetable tu opinión, pero cuando se entra en el mercado de históricos, clásicos y demás, los modelos de corta tirada, acabados especiales o con especificaciones más de circuito acaban siendo valoradas y más caras. Y eso vale tanto para un S2000 CR, como para un "Polo Arlequin".
#3889
epsylon8
epsylon8
  • 1,970 mensajes
Correcto, a eso me he referido.
Ya expuse que habrá quien valore la exclusividad de una tirada limitada , pero a efectos prácticos no aporta ninguna ventaja. Y obviamente eso solo es mi opinión , no crei que tendría que aportar la coletilla de " para mí"
El que busca un club Racer lo hará por x motivos , al igual que el que busque uno con la tapa de la radio firmada o mismamente el que busque una determinada convinacion de colores.
Pero a lo que yo me refiero es que a efectos prácticos ( yoo )no le veo ninguna ventaja especial.
Y si muchos perjuicios , para empezar no lleva un F20C
Y ya siguiendo en la linea de que aporte un rango superior en pista , yo no veo que los que los preparan pongan cosas del CR.
Lo que veo son preparaciones con piezas aftermarket de marcas como HKS , Spoon, js Racing , Mugen...etc
#3890
  • 12,910 mensajes
Yo respeto que haya quien valore una tirada exclusiva , pero un S de serie es más práctico y cómodo.
Fixed for you. :uff:
P.D: Cosa que TOODOS sabemos.
#3891
epsylon8
epsylon8
  • 1,970 mensajes
Yo solo cuestióno el absurdo sobreprecio por técnico a un auto que (para mí) solo aporta un punto de exclusividad de una tirada limitada como bien expuso npulsar Polo Arlequín.
Y no , no todo el mundo sabe , de hecho para eso está el foro para exponer diferentes puntos de vista.
Lo que desde luego si que sabe todo el mundo es el consumo y de sus variaciones dependiendo de lo que le pises o la Orografía del terreno.
XD
#3892
  • 12,910 mensajes
Pa tí la perra gorda. :P
Y la piruleta. :meparto:
#3893
  • 7,974 mensajes
A mi el CR me gusta.
Tanto la estética, con sus elementos aerodinámicos, las llantas y los asientos en alcántara, como el concepto en sí de hacerlo algo más liviano y con retoques en suspensión y estabilizadoras enfocándolo a un mejor comportamiento dinámico, aun siendo un coche de calle y que esos cambios supongan renunciar a algo de practicidad, que reconozcámoslo, tampoco es que sea lo más importante en el S2000.
Si acaso, creo que sería mejor aún con el 2.0, aunque tenga menos par, que siempre viene bien a la hora de mirar el crono, es la opción más acorde a la “esencia” del coche.
Entiendo que estén más cotizados.
Editado por S2000Gr, 18 May 2025 - 21:27:35.
#3894
EDVTEC
EDVTEC
  • 558 mensajes
https://www.autoscou...&utm_term=title
289x217.jpg € 35.900 Detalles Particular as24_product_24px_location_pin.png ES 08012 barcelona
#3895
npulsar
npulsar
    F20C
  • 2,111 mensajes
  • Coche:...
Vaya! Ese debió venir en el mismo barco que el mio de Japón! Y de kilometraje esta más o menos como el mio....
Es el de los MUY pocos silverstone con interior rojo y nacionales que aparecen a la venta en los ultimos años. Y que aparezca de absoluto stock es casi milagroso. El precio, me parece sorprendente la verdad. Han subido muchisimo desde la pandemia. Pero estaremos atentos a ver si se vende pronto o no... porque si lo vende rápido a ese precio me dan ganas de poner el mio a la venta porque con algo menos yo ya me conformaba  :veo:
#3896
epsylon8
epsylon8
  • 1,970 mensajes
No,tio....tú no.
Editado por epsylon8, 28 May 2025 - 13:07:03.
#3897
npulsar
npulsar
    F20C
  • 2,111 mensajes
  • Coche:...
No,tio....tú no.
:meparto: Todos tenemos un precio...
Curioseando en Coches.net, por 35.000€ hay Z3 M, Ford Mustang V8, Corvette V8, Jaguar FType, Varios 911, un 370Z con 30.000km, un Camaro cabrio.... en fin, que hay infinidad de cosas apetecibles que hasta hace bien poco tiempo costaban mucho más que un S2000, y estaban en un rango de precios uno o dos escalones por encima del S2000, que ha estado en precios de Z4, Boxters (sin S) y aparatos más mundanos.
Así que, o estamos ante la mayor burbuja de los S2000 (y hay que aprovechar a vender antes de que pete :meparto: ), o se esta valorando de forma más generalizada lo especial que es el coche. Se abren apuestas. ¿Vosotros que opinais? Yo creo que a 35.000€ no se vende.... y ojala me equivoque!
Editado por npulsar, 29 May 2025 - 12:31:44.
#3898
epsylon8
epsylon8
  • 1,970 mensajes
De todos esos que nombras yo solo cambiaría el S por el jaguar F-type y por depende que 911.
Añado un M2
Encontré esta oferta en AutoScout24
https://www.autoscou..._medium=unknown
Kilometraje: 19.000 km
Año: 10/2020
P.V.P.: € 49.000
Es para pensarlo , desde luego.
Editado por epsylon8, 31 May 2025 - 22:31:54.
#3899
aran01
aran01
  • 100 mensajes
Hay muchas unidades en venta por algo mas de 30.000€ y no veo que se vendan, si he visto venderse algunos por 26/27.000€ pero pensar que se pueda vender por 35.000€ no se, muy optimista por lo menos
#3900
gianfranco
gianfranco
  • 82 mensajes
  • Coche:Futuro s2000
En mi opinión un S nacional se paga entre 20 y 40, factores influyentes en el precio? Año de fabricación, kms, hardtop, pintura de origen o repintado, cantidad de dueños pero por sobre todo, EL ESTADO, y no hablo de si le queda más o menos pastilla de freno o neumáticos, que mucha gente confunde, esas cosas son baratas cuando hablamos de lo que se paga hoy por un S… lo que yo veo es que como puede haber unidades que realmente valgan 35/40 ya todos los propietarios estiman que su S los vale y luego el mercado (oferta y demanda) termina ajustando a la realidad, pero es evidente que el que tiene su S publicado hace uno o dos años es porque evidentemente está fuera de precio en relación a la unidad en sí…
