Toyo Proxes R888
177 respuestas en este tema
#141
  • 12.832 mensajes
Querrás decir que empeora en mojado.
Cierto! Razón tiene!
A ver, lo que dice el fabricante:
http://www.tyrerevie...8R-Launched.htm
Toyo R888R - Launched
The UK trackday favourite, the Toyo R888 has just been replaced by Toyo R888R, and it's a very good looking tyre. While the outgoing R888 will continue to be produced in certain sizes, the new R888R promises to improve the R888 in every area.
The new Toyo R888R
Building on what made the R888 so popular, the R888R looks to keep the all round flexibility for both road and track use, while dramatically improving on the dry-track grip and consistency lap after lap.
Available in two compounds, the R888R GG is fully compliant with the EU tyre labelling laws, making is one of the only track day tyres you can now legally drive to and from the circuit. The second compound, the R888R SG is only road approved in certain sizes, and is designed for higher grip on lighter cars such as Caterhams and Westfields.
Launching in 32 sizes, if the new Toyo R888R can offer improved heat management and higher dry grip as promised, Toyo should once again take the lead in the trackday tyre market.
http://www.demon-twe...toyo-r888r-tyre
The R888R is the hotly anticipated successor to the incredibly popular R888 tyre so it has some very big boots to fill, and that is exactly what this all new tyre has done. The R888R is not simply an evolution of the existing model, it has been completely re-engineered to give improvements in all areas over the R888. These improvements mean it performs even better on track and surpasses the latest tyre labelling regulations so it is totally legal to use as a road tyre. Other improvements include faster warm up times and increased dry grip with sustained performance over multiple laps and heat cycles. better steering response and driver feedback provide full control for optimised lap times.
The Toyo R888R tyre is a complete solution for performance driving and track day enthusiasts as well as serious racers and is one of the only tyres in this class which allow you to legally drive your car to and from the circuit.
http://www.rezulteo-...eferencia-27033
Toyo Proxes R888R: ¿el nuevo semi-slick de referencia?
Nuevos neumáticos Publicado el 15/12/14 por Julio
El Toyo R888 es un neumático imprescindible en el universo de los trackdays. El R888R, más radical y menos polivalente, acaba de presentarse y será propuesto como complemento de la gama.
Perfil asimétrico Toyo Proxes R888R
Tras el R888, Toyo presenta el R888R con perfil asimétrico
El Toyo Proxes R888 es un neumático muy conocido entre los aficionados a los coches deportivos y los que participan en trackdays. Este neumático, homologado para un uso en carretera, se dirige a automovilistas que buscan un producto con prestaciones extremas sobre seco.
También lo podemos ver en carreras de ascensión y en numerosos vehículos históricos. Su gran abanico de tamaños (de 13 a 20 pulgadas) hace que se dirija a un amplio grupo de deportivos. El R888R aspira a unas mejores y más extremas prestaciones sobre suelo seco; no obstante, sus prestaciones sobre suelo mojado no serán tan buenas como las del R888.
El Toyo Proxes R888R tiene una estructura diferente. En efecto, el R888 era un neumático direccional mientras que el R888R se convierte en asimétrico. Es un cambio radical que, en teoría, debería mejorar la capacidad direccional del neumático.
Toyo Proxes R888 vs R888R
Sin embargo, los cambios más importantes no son necesariamente los más visibles. Según los tests realizados por Toyo, el R888R es más rápido en circuito y más constante, además de contar con una mejor resistencia al calentamiento.
El feeling también se ha cuidado para mejorar las sensaciones al volante y para que evolucione la experiencia de conducción.
#142
  • 12.832 mensajes
Traseras cerca de los testigos y delanteras poco mejor.
NEVER again!
Desmontadas con 121996 Kms y en los testigos.
P.D: Guardadas para circuito.
#143
_BoSS_
_BoSS_
  • 2.158 mensajes
  • Coche:Honda S2000 AP1 F20C
Storm eso de dejar unas gomas medio listas para circuito no lo entiendo. Para otro tipo de coche mira... pero para el S con lo nervioso que es.. yo no me la jugaba. Cuando entré con las Potenza de serie en el Type R aún gastadas me lo pasé bien porque es dosificable y en cierto modo predecible pero durante las últimas vueltas que dí el agarre era muy bajo hasta tal punto de ser peligroso. Borré la mitad de las letras de los perfiles, dejándolos redondos.
#144
  • 12.832 mensajes
Buenas, _BoSS_!
Pues, mi experiencia es la contraria ya que las R1R y las Federal han funcionado MUY bien estando gastadas.
P.D: De todas formas, el tema es que están a punto de caramelo para rodar por la calle y NO las pienso tirar así, claro.
#145
_BoSS_
_BoSS_
  • 2.158 mensajes
Bueno si aún les queda vida como para rodar.. es otra cosa!
#146
  • 12.832 mensajes
Sí, claro.
Lo dicho, estado con 121996 Kms (testigos detrás y algo más delante):
P.D: Llevan 5077 Kms encima.
Editado por Storm, 25 enero 2019 - 16:04:26.
#147
  • 12.832 mensajes
ILanda las tiene listas para montar  en el taller:
Mamona! :P
Editado por Storm, 25 enero 2019 - 16:06:15.
#148
  • 45.270 mensajes
Jaumach ¿?.... :blink:
#149
  • 12.832 mensajes
En su medida? Poco. :P
Editado por Storm, 06 noviembre 2015 - 10:15:43.
#150
  • 45.270 mensajes
Poco puede ser mucho.... :klonk:
#151
  • 12.832 mensajes
En la nuestra ES MUCHO.
#152
  • 12.832 mensajes
Y acabo de teletransportar las nuestras allí para montar todo mañana por la tarde para el tinglao de pasado:
http://clubhondaspir...ito-de-navarra/
Editado por Storm, 25 enero 2019 - 16:07:12.
#153
  • 12.832 mensajes
Después de las tandas de hoy (http://clubhondaspir...-2#entry2190926):
Editado por Storm, 25 enero 2019 - 16:08:28.
#154
  • 12.832 mensajes
Jooder, cómo pasa el tiempo!
Ayer tuve que entrar a circuito con las Goodyear Eagle F1 Asymmetric 3 (menos mal que llovió!) mientras sigo a la espera de pintar el segundo juego de llantas y poder montar las R888 para terminar de quemarlas. :uff:
#155
  • 12.832 mensajes
La víiirgen!
http://neumaticos.ep...TOYR283557.html
Proxes R888R 215/45 R17 91W: € 158,69
http://neumaticos.ep...TOYR283558.html
Proxes R888R 225/45 R17 94W: € 223,54
http://neumaticos.ep...TOYR297000.html
Proxes R888R 255/40 ZR17 94W: € 209,22
Ni de coñen! :P
#156
  • 7.964 mensajes
Son bastante caros, sí. Dicen que van mejor que otros semis más económicos, pero la diferencia de precio es demasiada como para que la diferencia merezca la pena. Ahora, no habiendo problema de billetes...
Porca miseria...
#157
  • 12.832 mensajes
Porca miseria...
Yo hace tiempo que he llegado a la conclusión de que las R888 no merecen la pena para uso mixto calle-circuito:
http://clubhondaspir...-7#entry2168433
Van MUY limitados en mojado y tienen muy poca goma hasta que llegamos a los testigos.
Otra cosa es si pretendemos destrozarlas (hasta los alambres) sólo en tandas.
Mis siguientes serán R1R (again).
Editado por Storm, 31 octubre 2017 - 09:02:36.
#158
_BoSS_
_BoSS_
  • 2.158 mensajes
Yo creo que repetiré con las Advan Neova AD08R cuando toque.
#159
  • 12.832 mensajes
Maldito! Ya me está haciendo dudar:
http://clubhondaspir...-3#entry2138806
Otra vez. :P
P.D: ILanda decía ayer que NUNCA volverá a Toyo después de haber probado las R888R y los slicks. Que se pasan rápido de temperatura. :uff:
Editado por Storm, 31 octubre 2017 - 10:45:32.
#160
_BoSS_
_BoSS_
  • 2.158 mensajes
Es que las R888 son cojonudas pero para track, el inconveniente es el elevado precio y escasa duración (a costa de prestaciones). Yo las descarto.
R1R son mas razonables y equilibradas, pero con respecto a las Neova siguen teniendo el precio mas elevado, y de prestaciones creo que andan muy similares.
