Otra centralita que está desmontada del coche y lista para coger el camino hacia Galicia ![]()
Qué impaciencia ![]()
Im using Brembo GT kit ( 328x32 composite 2 piece rotors ) for CL9, yep , its pricey but ... best money can buy for now.
Brakes must have a balance. Heavy rotors can accept more heat but that weight also affect acceleration , fuel economy , handling and ride quality. You need to remember that keeping unsprung mass low is very important. CU2 has better rotors from the heat capacity point of view but stockish pads are crap and gave up early. CU2 calipers are hella heavy, they been made as cheap as possible (( I dont recommend swapping CU2 brakes to CL9 , you will have more confident braking but you will lose too much in other parameters.
Brake upgrade options are rather wide , euro-r swap , rather cheap and really effective one, lots of custom solutions based on Acura TL or DC5 calipers , lots of BBK kits , rotora , brembo , racingbrake , wilwood and few others. You need to try to increase heat capacity and reduce weight at the same time !!
hi littlebo ![]()
could you compare the results with two of the most praised engines of the market?
do you think a 2.4 cl9 reflashed works more or less as a 6L bmw 325 or 330 ???
these atmospheric bmw engines have a powerful and equilibrated range in almost all their revs curve.
or maybe as a golf GTI MK5 200 hpw? but this is a turbo engine with more power in low revs and less in the highs than bmw
hola Littlebo ![]()
podrias comparar el resultado con dos de los motores mas alabados del mercado ?
crees que un accord 2.4 reprogramado tiene un funcionamiento parecido a un bmw 325 o 330 de 6 cilindros gasolina ???
esos motores atmosfericos bmw tienen un rango equilibrado y poderoso en casi toda su curva de rpm´s
o quizá como un golf GTI V de 200 cv? pero este es un motor con turbo con mas fuerza abajo y menos en altas que el de bmw
No difference AT or MT . Its tune for engine , not for tranny .
Dice algo de los frenos??? Y seguro muy interesante!!!???.
Dice basicamente que usa el KIT GT de brembo (328x32 composite 2 piece rotors) en el CL9, que es caro pero es lo mejor que el dinero puede comprar ahora mismo.
que hay que tener un balance entre peso del freno y cantidad de calor que pueden expulsar, y que los frenos del CU2 son muy pesados y las pastillas de serie son una basura, pero que los rotores son buenos en cuanto a disipaciond e calor. Que no recomienda poner frenos del CU2 en el CL9.
Que opciones de mejora de frenos osn variadas, como el swap de euro-r, y muchos basados en pinzas de Acura TL o DC5, kits BBK, rotora, brembo, racingbrake, wilwood, etc. Necesitas incrementar capacidad de calentamiento y reducir peso a la vez.
ahi lo llevas
Puuuuff!!!! Que lío!!!!!
Tu quieres cambiar de frenos???
El que quiera unas pinzas Rotora de 4 pistones buenas, bonitas y baratas que se ponga en contacto conmigo. Pero ya aviso que el problema será conseguir discos ya que Rotora ha dejado de fabricarlos. Yo he buscado bastante y no los he encontrado, habría que intentar buscar unos discos fabricados por otra marca que sean compatibles, y esto no lo he hecho.
Stoptech kit is good to go , all parts for em available. but you need to check if they will fit 17 wheels . i guess they will but not into stock ones or spacers needed.
George, i can say for shure that CL9 MT with reflash and headers is faster than Golf GTI mk6 dsg and any bmw 325 . My buddy won the local drag races and his main competitor been tuned 325 with no interior , he had stock CL9, reflash , euro-r tranny .
not shure about 330 , noone of my customers tried vs.
https://www.youtube....?v=_ocZBwAnSUo
And heres same cars but CL9 isnt reflashed yet.
see the difference ))
To be on vtec all gears with AT tranny you need to use sportshift and rev to the limit , this way you can get all power out of it.
Losses on AT is really big, something like 30hp and 20 hp more than MT, at least stock car usually have 155-160whp and MT on same dyno has around 175-180whp
George!!!! Traduce!!!!!!
Look , its not better for AT or MT . Its THE SAME. The only difference between AT and MT - AT transmission has more power losses because of torque converter and also it has longer gears that also affect acceleration. Thats why AT accord is slower than MT for 3-4 bodies on the run.
So you have to compare AT with AT and MT with MT . Thats all. With reflash you will be equal or faster than AT 325 , but not MT one. And with reflash you will be faster than MT Accord !
Littlebo, any new about reflash in czech republic? I'm still thinking if it is in Praha, I go for it one weekend...
I had few requests from CZ but still nothing special to have a dealer there. Need to find their local forum and post some info there. You can help with this if youd like.
Colaboradores, Vendedores oficiales →
CHS Racing - Taller Oficial del Foro →
Reprogramación i-CTDiComenzado por CHSRacing , 18 marzo 2016 - 13:35:47 |
Reprogramación I-DTECComenzado por CHSRacing , 18 marzo 2016 - 12:03:48 |
