Argumenta eso, yo no le veo el sentido ...
#161
Escrito 11 enero 2014 - 11:40:04
#162
Escrito 11 enero 2014 - 16:04:07
Pues muy sencillo. Para ganar potencia con la repro, entre otras cosas, lo que se hace es empobrecer la mezcla (en WOT) ya que de origen es demasiado rica. Si a esto le añades que la combustión del GLP genera más temperatura que la combustión de la gasolina.......
#163
Escrito 11 enero 2014 - 17:31:04
Le daré unas vueltas y lo consultaré con el instalador ![]()
#164
Escrito 12 enero 2014 - 10:46:10
Imagino que entonces con que pasase a gasolina cuando estés en WOT, sería suficiente... ¿no?
#165
Escrito 12 enero 2014 - 13:49:14
#166
Escrito 12 enero 2014 - 14:45:09
To lean a little not equal to make it lean !!! Average AFR of stock CL with reflash is 12.6-12.9 across the revs under WOT. Which is a golden standart. Good intake and headers can make it as lean as 13.5-13.7, despite this, exhaust temperature isn bad and harmful. For example, my car is tuned to 13.2 AFR, nice power and good fuel economy. What can i say about CU2 AFR... This engine has high tendency to knock, much more than CL9, i dunno why, bad combustion chamber geometry or something else ... And because of that, R series of firmwares ( KR , cars for ex USSR regions with bad fuel quality like Russia and Ukraine ) has much more rich mixture compared to E series ok que region, Europe. I see 10.8-11 in stock car datalogs . Its God damn so rich ! But i dont see turbo in CU2 to justify this LOL ))
4ngel , you can check stock CU2 log under WOT with your flashpro, i saw 11.2-11.8 there. Also very rich. Honda, instead of investigation of engine design flaws solved problem with rich mixture. Nice trick.. And cut ignition. How do you like spots with 14-16 degrees in CU2 cal ?? And what we have with rich mixture ? Bad fuel economy and more stress to oil film in cylinders, which cause more premature wear...
Id like to say that best way to judje is to use EGT sensor, its not that simple but 100% truthful.
#167
Escrito 12 enero 2014 - 15:32:12
Littlebo, but they are talking about your reflash+LPG... and 4ngel says that he is not sure he would do it...
#168
Escrito 12 enero 2014 - 16:28:03
El traductor de Google hace estragos por donde pasa ![]()
Con el HDS se pueden ver los valores de mezcla. Cuando hago la transformación de cualquier Honda a GLP utilizo el HDS para ajustar lo mejor posible la centralita de GLP y que el motor vaya como tiene que ir. La verdad es que me he quedado un poco flipado al ver los valores de mezcla, por ejemplo el Legend en WOT va alrededor de 11.8. (ni que fuese turbo).
Al hacer la repro se empobrece un poco la mezcla pero siempre manteniendo un margen de seguridad. Yo al mio lo llevo en torno a 12.9 - 13.0
#169
Escrito 12 enero 2014 - 17:16:27
Mañana se va mi ECU para tierras gallegas!
#170
Escrito 12 enero 2014 - 19:19:24
Angel, sabes que las centralitas de GLP tienden a enriquecer la mezcla, yo la llevo bastante ajustada y aún así, hace unos dias le metimos el ordenador de Indi y la sonda lambda daba 0.99-1
#171
Escrito 12 enero 2014 - 21:07:15
Las centralitas de GLP leen el valor de los pulsos de inyección de los inyectores de gasolina y le aplican un % a mayores. Si tienes la mezcla en esos valores de lambda pisando a fondo (14,6:1 AFR) quiere decir que la mezcla es muy pobre para esas condiciones. El Accord con la electrónica de serie, pisando a fondo seguro que ronda un valor lambda de 0.82 - 0.85.
Supongo que el valor de lambda de 0.99 - 1 que has visto en el PC de Indi habrá sido en circulación normal con el motor funcionando en closed loop. Y vayas a gas o a gasolina, en closed loop, ya se encarga la ECU del coche de ajustar la mezcla para obtener ese valor de lambda tan cercano a 1.
#172
Escrito 12 enero 2014 - 21:53:16
Si os llegase a entender sería muy feliz, os lo prometo.
#173
Escrito 12 enero 2014 - 22:00:32
¿Que no entiendes mister? Pregunta lo que no entiendas, tampoco es tan dificil...
#174
Escrito 12 enero 2014 - 22:17:22
+11111111111111111111111111111111111
#175
Escrito 12 enero 2014 - 22:19:28
Y creo que no es la unica ![]()
#176
Escrito 12 enero 2014 - 22:23:54
la centralita de glp se ajusta tanto a ralentí como en marcha y se puede aumentar o disminuir la mezcla con respecto a gasolina. Si haces el ajuste automático es cuando mide la inyección en gasolina y pone el equivalente en glp, en este caso la mezcla siempre queda ligeramente rica. Al menos así funciona BRC y GFi.Las centralitas de GLP leen el valor de los pulsos de inyección de los inyectores de gasolina y le aplican un % a mayores. Si tienes la mezcla en esos valores de lambda pisando a fondo (14,6:1 AFR) quiere decir que la mezcla es muy pobre para esas condiciones. El Accord con la electrónica de serie, pisando a fondo seguro que ronda un valor lambda de 0.82 - 0.85.
La lamda la medimos a ralentí, en gasolina y gas.
Desde Tapatalk
#177
Escrito 12 enero 2014 - 22:33:56
Desde Tapatalk
También en WOT?
Lo de la lambda por eso dice 4ngel que siempre te va a dar 1, porque la medisteis a ralentí con el motor caliente... por lo que está en closed-loop y te va a dar 1, porque la ecu mide la sonda de O2 e inyecta en función para que de siempre 1... el tema es probar con WOT, sino sabes que te va a dar 1...
Editado por FerK24Z3, 12 enero 2014 - 22:35:30.
#178
Escrito 13 enero 2014 - 16:35:26
Eso tiene sentido, tienes razón.
Que es WOT ? por que mo voy a meter a indi, el PC y el adaptador en el coche para medirlo en marcha ...
jejeje, supongo que hay forma de hacerlo, quizás con el DashCommand por OBDII ... ![]()
#179
Escrito 13 enero 2014 - 17:01:50
WOT es Wide Open Throttle, que significa, con el pie en el radiador...
No se la manera que habrá, imagino que lo mas sensato será medirlo sobre rodillos, porque sin carga en punto muerto a mi me parece una burrada, pero a lo mejor...
#180
Escrito 13 enero 2014 - 17:04:03
con el pie en el radiador... ? será en el acelerador ![]()
Bueno en parado se puede poner a régimén, aun que no tenga carga ...
Responder en este tema
Etiquetado también con una o más de estas palabras: Repro, centralita
Colaboradores, Vendedores oficiales →
CHS Racing - Taller Oficial del Foro →
Reprogramación i-CTDiComenzado por CHSRacing , 18 marzo 2016 - 13:35:47 |
Reprogramación I-DTECComenzado por CHSRacing , 18 marzo 2016 - 12:03:48 |
Citar
Multicita
